Buhler Allied loader valve control problem
/ Buhler Allied loader valve control problem #1
Jim_in_Omaha
Omaha area
LK3054
I just got a used Kioti lk3054 with a Buhler 190 loader with 43 hours. It has a joystick control. The problem is that when I push the stick forward to lower the loader lift arms, it acts like it can hardly move it and the pressure line moves indicating high pressure. Going up it works fine. I reversed the lift cylinder lines and it goes down great, but goes up slow.
Also, it will not lift the front of the tractor by the lift arm cylinders. But if I curl the bucket down from a level position towards the ground it will easily lift the front of the tractor.
Its as if the valve assembly is not letting returning fluid back easy enough when lowering the bucket. As far as it not being able to lift the tractor, I might have to check the pressure. I'm not so concerned about lifting the front of the tractor as I am about lowering the lift arms correctly.
Also, if the bucket is off the ground and I put the level into the float position, it drops very slowly.
There is a allen screw with lock nut on top of the valve assembly. I adjusted it and it seemed (note the seemed) to control the balance of where the curl control is left to right on the joystick. I checked the lines back to the hydraulic outlet on the tractor and the Tank line and Neutral line were backwards. After changing it, it made no difference in the performance.
Is there a relief valve adjustment for the downward motion? From my diagnostics it appears to be in the valve assembly. I know that the cylinders for the lift arms are 2' diam with 1.5" cylinders. The bucket is 2" diam with 1.25" cylinders.
Thanks for any input.
Jim
I was thinking, on the line that would be used to push the lift arms up there is a large hex extension about 1 3/4" long with a pin through it that is connected to the valve body. The hose is then connected to it. I'm thinking that this is a flow control orfice or something being that its on a float joystick. I am going to take it off and see if something is in it. Might put the hose on without it to see how it works for testing.
thx again.
Jim
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
2022 SANY SY5OU EXCAVATOR (A63276)
2022 SANY SY5OU...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
2007 Talbert T4BDW-45-HRG-1-T1 45 Ton Detach (A62679)
2007 Talbert...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
2006 GODWIN GHP45KW-RC-45KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
