Backhoe BUCKETS any by other companies
   / BUCKETS any by other companies #1
mytonka
md
Terramite T5C
I know that backhoe buckets (loader & hoe) are like hens teeth.
However I was wondering if anyone knows of a direct replacment or one with minor welding required.
Or a good sorce for used buckets.
   / BUCKETS any by other companies #2
Look on smd.craigslist.org there's a guy, Jordan, in Leonardtown area that always has a mix of attachments.
Pretty much any competent welder fabber can convert. In fact it is pretty easy to convert to skid-steer or mini skid steer type of setup and have a swappable setup for the loader.
My t6 is skidsteer compatible and the t5c I'm building is going to be mini skid steer and power trac compatible.
Hi agjones
Thank you I will look into the fellow in Leonardtown.
I too have had a few hoe buckets modified but was hoping to find a new solution.
With all the manufactures out there there should be one that is compatable
thank you again
   / BUCKETS any by other companies #4
I think the most likely direct fitup is bh buckets from older case, vermeer or ditchwitch trenchers.
2016 Ford Taurus SE Sedan (A48082)
2016 Ford Taurus...
2018 Mitsubishi Eclipse Cross SUV (A50860)
2018 Mitsubishi...
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
UNUSED 20PCS 2in. Polyester Lifting Strap (A50860)
UNUSED 20PCS 2in...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
