bucket won't lift
   / bucket won't lift #1
refueler
I plowed snow the other night and everything worked right, but when I went out the next day to clean up the bucket wouldn't raise it would put down pressure and dump and curl the bucket. When you try to raise the bucket you hear the relief valve lift. I tried reversing the hoses lift lower hoses were swapped to the dump and curl. This made no difference the bucket won't lift. I looked at the hydraulic oil and it looks milky. Last summer I broke a line and I put a bargain oil the met jd specs so I'm going to use the rest of the bargain oil to flush the system clean the screen and change the filter and replace the oil with jd oil. If anyone has any suggestions I would appreciate it.
   / bucket won't lift #2
Sounds like you have an ice problem in your cylinder-s try heating them up NOT with a torch.
   / bucket won't lift #3
How cold is it? Milky fluid indicates water contamination, if its below freezing then the water in the oil is possibly frozen.
2013 GMC Yukon Denali 4x4 SUV (A51694)
2013 GMC Yukon...
2013 Chevrolet Impala (A51694)
2013 Chevrolet...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
