Loader Bucket Will Not Roll Forward
/ Bucket Will Not Roll Forward #1
freewookie
Guthrie, OK
JD GT235, DK40SE HST
The bucket on my DK40 will not roll forward. It will go forward three or four inches but no further. I see the hydraulic hoses flexing but still nothing. I've greased all the zerks thinking one of the joints is frozen up. Was working fine the other day then wasn't today.
/ Bucket Will Not Roll Forward #2
Try unhooking all the hydraulic couplers from the FEL valve under the right step and hook them all back up. (while engine is off of course):) May or may not fix anything but worth a try, doesn't cost anything.
/ Bucket Will Not Roll Forward #3
Could you have a rock, stick or? Jammed at your bucket pins. :)
I'll try disconnecting and reconnecting the valves.
I looked for sticks or rocks but didn't see anything. I took the bucket off so I could get a better look but by that time it was getting dark.
/ Bucket Will Not Roll Forward #5
When i last had that problem, I had bent the **** out of the rod on one cyl. A big limb got caught, fell out, but had already ruined the cyl.
Can't remember hitting the cyl with anything. I was thinking about un hooking the cyl to see if it would operate unattached.
/ Bucket Will Not Roll Forward #7
Reset the QD's in the curl circuit.
If your line is flexing,and the cyl is not at the end of travel, then the QD is not connected properly
Reset the QD's in the curl circuit. If your line is flexing,and the cyl is not at the end of travel, then the QD is not connected properly
Reset? Sorry how do I that?
Thanks guys that was the problem. I started tracing the hoses back and when I tugged on one of the hoses it popped right out.
I went through a heavy thicket the other day and must have snagged one. I did a visual inspection after I went through it but guess I should have tugged on the hoses.
Need to study up on hydraulics and how they work!
/ Bucket Will Not Roll Forward #12
Yes, it seems the majority of these type of complaints are related to the couplers.
/ Bucket Will Not Roll Forward #13
Happened to me today as well, The curl and dump qd's had popped out pulling out a patch of stickers.
2012 WESTERNSTAR 4900FA (INOPERABLE) (A63569)
2012 WESTERNSTAR...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
EZ Guide 500 Remote (A65640)
EZ Guide 500...
2022 EZ-GO ELITE...
Demco Lowboy Trailer (A65563)
Demco Lowboy...
B&W Gooseneck Ball, Unused (A66408)
B&W Gooseneck...
