Bucket size
/ Bucket size #1
joshua5438
Easley, SC
Looking to buy
I am looking to purchase a CK3510 and was wondering what size bucket is best. I have been given several quotes and they all say KL4030 loader with 60" or 66" QA Heavy Duty Bucket. Anyone have an opinion if one would be better suited for the 3510 more than the other?
/ Bucket size #2
60" if you are using 5' stuff behind it like bush hog, tiller, or box blade. Just makes driving and lining up next pass easier knowing corner of bucket is where corner of whatever on 3pt is....
The difference of 60" vs 66" is probably a couple cu ft of material? Look at spec sheet to be sure, but is probably insignificant difference.
/ Bucket size #3
What is the width of the tractor?
What will you use your loader bucket for primarily?
I found my bucket to be too small so I bought a bigger one for my needs, but I did lose some digging capability when I went to the bigger bucket which doesn't matter to me because I don't dig much with it, for me it's a snow, firewood dirt bucket.
/ Bucket size #4
Either bucket is fine for that tractor, but if you will be doing much digging, even with a tooth bar, the 60" will penetrate with less resistance.
/ Bucket size #5
As mentioned a larger bucket will work well with mulch,firewood and snow removal.
If your working with dirt & stone you might opp for the smaller bucket.
2007 JLG 450AJ TELESCOPIC BOOM LIFT (A65056)
2007 JLG 450AJ...
1 PALLET OF MISC TRUCK PARTS (A66091)
1 PALLET OF MISC...
2013 FREIGHTLINER CASCADIA(INOPERABLE) (A67714)
2013 FREIGHTLINER...
2019 Autocar ACX Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2019 Autocar ACX...
2014 FORD ESCAPE (A66091)
2014 FORD ESCAPE...
2015 GMC SIERRA 3500HD CC (A67714)
2015 GMC SIERRA...
