Bucket Removal on BX FEL
   / Bucket Removal on BX FEL #1
GFB
Southern Illinois - Union County
BX1800
I want to take my bucket to a welder to put on chain hooks. What is involved with removing the center connection where the lift cylinder is attached? A quick look last night in semi-darkness made we wonder just what might fall out when I removed the pin. Anyone having the benefit of experience they can share will be appreciated. Thanks.
   / Bucket Removal on BX FEL #2
Remove the small cotter pin from the retainer pin. Remove the retainer pin and drive the main pin out from the side. The only thing you have to be careful is not to damage the zirc that is recessed in the main pin, other than that, it's a solid piece without anything else to worry about. Then remove the other two pins for the loader frame, but they only have larger cotter pins keeping the main pins in place. Drive them out as well.
When reassembling, it's easier to temorarily install all main pins, without worrying about hole alignment for the cotter pins. Have somebody watch the holes as you turn the bucket and eventually the holes will align themselves as long as you have them at the right depth. A small alignment tool will help finish the job at this point.
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A55973)
2015 Freightliner...
2021 Ford F-350XL (A57148)
2021 Ford F-350XL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2007 Heil Heavy Duty Aluminum Tank Trailer (A56435)
2007 Heil Heavy...
2019 CATERPILLAR 259D SKID STEER (A52709)
2019 CATERPILLAR...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
