Bucket Pallet Fork Fabrication
   / Bucket Pallet Fork Fabrication #1
BigBoyToys
MA
Kubota B3030
Needed to build a set of pallet forks to lift some plywood for a new building. I wanted to load the plywood in the long way to get the it up higher to unload. Fortunately I got a 20' piece of 6" C-Channel from work that had been laying around since our new building was build 6 years ago. I had everything else I needed except some one inch square tube to support the forks under the bucket. This was needed to level the fork to the 1" cutting edge.
First was to cut the c-channel to length. I wanted to have the forks extend 4' off the front edge of the bucket. So the overall length was 6'.
I then cut some 3" c-channel to act as vertical backstops on the forks.
Some 1/4" plate was cut, drilled and welded to the fork and vertical stop for a connection point.
I bent a 2" piece of 1/4" bar for the rear connection point.
Last was to weld some 1" square tube for keeping the fork level with the cutting edge on the bottom of the bucket.
I then drilled a 3/8" hole at the end of the forks to mount a 2x6 between them to support a 4" wide piece of plywood with the end of the plywood extending into the bucket.
Here's the forks set wide to allow the plywood to go into the bucket.
Here I have the plywood in position to unload in the building.
Shot of the back end of the fork with the mounting points and 1" tube supports. There is a short lip so the fork can "hang" on the bucket while attaching the straps.
How the fork sits under the bucket when mounted.
Front edge bucket mount.
Rear bucket mount.
Here they are mounted in a normal position closer together.
So far they served the intended purpose of getting the plywood up high enough to load into the building. I know they will be used for a lot more jobs! :thumbsup:
   / Bucket Pallet Fork Fabrication #2
Hey, if a man has a welder and some steel, about anything is possible.. Looks good..:thumbsup:
I initially purchased it for a Jeep build I did with my son.
It's not something you use a lot...but sure is handy to have around!!!
   / Bucket Pallet Fork Fabrication #4
Looks pretty useful to me. Nice work.
   / Bucket Pallet Fork Fabrication #5
Once you are introduced to welding you can't live without, next you become a scavenger and collect every bed spring that the neighbors put out to trash.
As you graduate you visit the recycle yard and bring home 'deals' that you might need.
Shucks even 3 or 4 inch scraps might become handy.
Ever notice that metal you hoarded for 10 years and tossed last week is just exactly what you needed today?
You gotta have an understanding 'better half'.
Bed frames...did you say bed frames... hahahahahaha
I never throw away anything! I keep a "Scraps Bucket"...you never know when you'll need that little piece of something!
   / Bucket Pallet Fork Fabrication #7
Oh now! That was a great way to repurpose them old bed rails. That looks like fun!
   / Bucket Pallet Fork Fabrication #8
The most frustrating drilling job I ever came across was in a bed frame. That metal was HARD!
:thumbsup: First time trying it out.
How does that old saying go...A Family That Shoots Together, Stays Together! :D
LMC LOT IDENTIFIER 126 (A53084)
LMC LOT IDENTIFIER...
JOHN DEERE LOT IDENTIFIER 69 (A53084)
JOHN DEERE LOT...
UNUSED RAYTREE RMSG29 - 29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
PALLET WITH TROYBILT TBE304 EDGER (A51248)
PALLET WITH...
2018 Jeep Grand Cherokee SUV (A51694)
2018 Jeep Grand...
