Bucket on d100 series
   / Bucket on d100 series #1
Jchuchla
D140
Anyone ever put a Johnny bucket on a D100 series? Or maybe an older LA series? I see they say it fits, but I'm skeptical about performance.
If so, your thoughts on it?
   / Bucket on d100 series #2
that tractor is not designed for ground engaging equipment. You have plent of HP, but the transmission wont take it.
   / Bucket on d100 series #3
If so, *your thoughts on it?
*The lift hight is only a few inches which greatly reduces the usefullness of it .;)
   / Bucket on d100 series #4
I agree with Greenrules and LBrown, in addition the front spindle assemblies won't last long. For ground engaging work utilizing a mower use an x500 and up.
I still use a wheel barrow quite often, better than a johnny bucket in most cases.
   / Bucket on d100 series #5
This is the only kind of bucket you want on a D100 series. If you need to haul something larger, get a towable dump cart, but don't waste your time with a Johnny Bucket.
Thanks for the input. You're pretty much confirming my suspicions. I was just curious since the D and LA series are actually specifically listed as supported models on the Johnny bucket website. I really didn't plan on doing much "ground engagement" work, but rather more moving and spreading type of work with landscape stone and mulch and such.
I'm still curious though if anyone has actually made the jump and trusted their website and bought one for these small mowers. I'd be interested to hear the experience.
   / Bucket on d100 series #7
I would recommend you pull off a front wheel and inspect the spindle assembly to decide whether you think it can handle the weight long term.
Seriously it would be easier to use a cart, wheelbarrow, shovel and rake to accomplish your tasks.
That's exactly what I've been doing thus far. And after a weekend moving a few yards each of dirt and lava rock, I started looking for a better way.
So would your negative reccomendation also apply to snow equipment? I can't imagine that a small bucket would be much more stress than a plow or blower.
   / Bucket on d100 series #9
I wouldn't want anything heavy on the front of a 100 series imo. That said the problem with a johnny bucket is all the manuevering you need to do in soft ground to get the material where you wan't it. Using a wheelbarrow is simply easier to use.
At least with the snowblower and blade the downpressure is relieved when you are working it for the most part. I would be more inclined to use either of these two tools than the johnny bucket.
I have been working the last few days cleaning up a lot for a sick neighbor adjacent me. Lots of hand work and some tractor work, BTDT.
   / Bucket on d100 series #10
if Im not mistaken, the front wheel assembly on the 100 series has plastic bushings. The bigger tractors have greasable bearings.
Two Post Car Lift (A50120)
Two Post Car Lift...
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
378574 (A51573)
378574 (A51573)
2010 PETERBILT 340 (A52472)
2010 PETERBILT 340...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
