Bucket mod
/ Bucket mod #1
Freds
NW PA
Kubota L3130HST & ZD326s
I added some tool holders to my bucket today. There's four altogether, made out of 1/4" plate. Here's two of them being used to hold a shovel.
/ Bucket mod
Here's a pic showing the versatility.... holding a rake.... shown with optional BS (bungee strap).
/forums/images/graemlins/grin.gif
/ Bucket mod
Speaking of BS..... /forums/images/graemlins/grin.gif
Actually this is the idea I had a month ago or so for pushing fence posts into the ground. Check it out.
/ Bucket mod
From the rear. You can see I welded to the upper lip of the bucket and the top of the bucket, so it should add quite a bit of strength if I want to hook a chain onto the lip or through the brackets.
/ Bucket mod
Here's one with a T-post hooked on with the bungee.
/ Bucket mod
Lifted into the air.
/ Bucket mod
Hanging nice and plumb. I made the receiver big enough for chainlink posts.
/ Bucket mod
Pushed into the ground. I went in a lot further than I usually hammer them in.
/ Bucket mod
Whalla! It's as plumb as you can get the tractor side to side and stayed pretty plumb the other way, too. Putting the snow fence up this year should be a breeze /forums/images/graemlins/cool.gif
/ Bucket mod #10
Very nice /forums/images/graemlins/cool.gif
Now, show me a quick tool for removing t-posts without having to get off and hook up a chain /forums/images/graemlins/grin.gif
/ Bucket mod #11
Very, sporty. I'm sure you will find even
more things to do with that setup
/ Bucket mod
I hear ya Jerry. It's a shame..... but we have to get off the tractor sometimes /forums/images/graemlins/tongue.gif
Thanks for the compliments, guys. Now I need some fencing to put up /forums/images/graemlins/smile.gif It's no harder lining up the bottom of the T-post than using a PHD and the "BS" keeps them all facing the same way.
/ Bucket mod #13
Freds,
You could get really crafty and make a grapple and have the rake handle double as the grapple hinge !!!!
Seriously though..... great job ! Pretty crafty post driver !
/ Bucket mod
</font><font color="blue" class="small">( and have the rake handle double as the grapple hinge )</font>
Hmmm, I wonder what the " tensile strength " of a fiberglass rake handle is.... or would that be ductility?
/ Bucket mod #15
I like it! A very simple solution to a problem we all have.
But how do you carry a shovel with a "D" handle? I can think of a couple modifications that would suit MY needs, but you've certainly given me something to ponder while I think about my next round of modifications.
/ Bucket mod
For you, Bob. Use optional "BS" to secure in place /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
It's kind of funny how my only D handle shovel fit right in there, though... Sometimes things work out without trying...
Actually, I like tossing my shovel and two rakes into the round cross-member between the FEL arms, but then I never have anyplace "skinny" I need to get into and the ones I use the most don't have D handles.
/ Bucket mod #18
Freds, great innovations!
Where I am, I hit rocks when driving T posts, thus can't use an off bucket center driver. I do use a sleeve of pipe over a T post centered under the bucket... takes a buddy to hold it in position... and the length is set so that when the bottom of the sleeve hits the ground the post is at the right depth. The full length sleeve prevents bending/breaking when a rock is encountered (usually) and allows a little "pounding" on the T post with the bucket bottom. I put extra weight either in bucket or on front to assist in down pressure before front wheels come off the ground... and they WILL come off the ground when solid rock is hit.
2015 ALTEC AT200 MOUNTED ON 2015 FORD F450 XL SD (A67148)
2015 ALTEC AT200...
TEST YOUR BID BUTTON! (A64278)
TEST YOUR BID...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2026 Electric Tricycle (A64194)
2026 Electric...
Kohler Gasoline Air Compressor (A64553)
Kohler Gasoline...
