Bucket metal thickness?
/ Bucket metal thickness? #1
kuby
Alberta, Canada
L 245DT
Does anyone know what thickness of metal for makeing a loader bucket in the 25-35 hp range??
/ Bucket metal thickness? #2
Ive built a few for folks with loaders and the thickest Ive used was 1/4 and 5/16. I made for an old 8N Ford had 1/8th sheet metal for the shell and 1.5 by 3/16 flats for the bottom ribs. I also used the 1.5x3/16ths to make the cutting edge later I used to for a support for when I added a bucket extension to it. The very last bucket I made was 3/16ths sheet I ordered sheared to the exact bucket width. I took it over to my cousins fab shop and used his homemade Brake to form the bucket shell then I made the side plates, brackets, and ribs.
/ Bucket metal thickness? #3
Homemade Brake for 3/16" steel? We need photos. /forums/images/graemlins/grin.gif
/ Bucket metal thickness? #4
Ive seen it bend 6 foot sections of 3/8th plate but the plate had to be slotted on the bendlines. Its 2 inches shy of 8 feet because they got into production of T1 steel demo bodies for dump trucks at on time and warped it. I had some a tree spade bucket bent today their. He gets 15 bucks an hour for its use I cant go wrong there. I can get up to 5/16ths bent at the steel supply Tigrett Steel for free with any order ad long as its not super complex. But I like to do it myself somtimes with my cousins machine and his help when needed. Hes the one that made the homebuilt TLB I posted sometimes back all the tapered arms are bent on the same brake. Hopefully next week Ill have to take a couple dumpster off another lot near his shop and Ill drop by for a minute.
I am thinking 3/16 is what I am going to use. That should be plenty heavy enough but hopefully not to heavy for my tractor.
/ Bucket metal thickness? #6
</font><font color="blue" class="small">( I am thinking 3/16 is what I am going to use. That should be plenty heavy enough but hopefully not to heavy for my tractor. )</font>
That'll work. Use 1/4" doublers and you wind up with 7/16 at all the stress points.
Can Am Defender (A63688)
Can Am Defender...
3096 (A63117)
3096 (A63117)
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2004 Dodge Ram...
(2) BUCKET & BOX OF ASSORTED BOLTS & NAILS (A64281)
(2) BUCKET & BOX...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A64280)
UNUSED CFG...
