Bucket lights?
   / Bucket lights?
Thanks for all the posts! /forums/images/graemlins/smile.gif I don't always have my ROPS up though, due to the trees around the edge of my field. I also wonder about the glare and bugs associated with them mounted there.
The primary after dark use will be bushogging.
thanks again,
Dave
   / Bucket lights? #12
Dave I don't know of anything that you might do to discourage the bugs from your lights, even our headlights alone attract bugs without the canopy lights being on. Maybe you could hang a bug zapper from your ROPS between your lights? /forums/images/graemlins/laugh.gif
   / Bucket lights? #13
I tried YELLOW automotive fog lamps for the first set lights I mounted to my ROPS, and they seemed to attract LESS bugs than the lights I have up there now. But they did not eliminate the bug issue. The only reason I switched from yellow to white light was because I do finish mowing at night sometimes and the yellow light did not provide enough contrast against the grass for me to see well enough. I also went from 35 watt lights to 55 watt lights when I converted. I suppose I could have tried a 55 watt yellow light, but when I bought the new lights the store didn't have 55 watt yellow in stock.
As for glare, I don't have any problems with that as long as I don't turn around!
I also have 2 lights facing the rear for snowblowing mounted on the ROPS and 1 rear aux light at the base of the ROPS. Depending on snow conditions I either use the top lights or the bottom light.
   / Bucket lights? #14
Bob,
Where did you get your water proof switches?
I tried to find them and every marine place I contacted wanted $65 or $70 + shipping for a set of 3 switches. /forums/images/graemlins/shocked.gif
I tried auto parts stores locally and they only have interior switches, nothing for outside/weather resistant use. /forums/images/graemlins/frown.gif
Thank you for your help.
CJ
   / Bucket lights? #16
Yup, Don, that is the place.
I think several others on TBN have also used Go2Marine for switches.
If you want a clean looking install, they also sell a modular mounting bezel for the switches. Actually they sell 3 different ones depending on your mounting needs. One version is a simple single bezel for mounting one switch. If you plan to mount 2 switches, you need to order end unit bezels and snap them together. If you plan to mount 3 or more switches, you need 2 end units and at least 1 middle bezel unit.
When I did my install, I originally bought 2 end units and installed only 2 switches. About 6 months later I added a 12-volt outlet, and I wanted it connected to a switch, so I ordered another switch, a middle bezel unit, and popped out the old set up, un-snapped them, clicked in the middle unit, enlarged the mounting hole in the fender, and popped the 3 switch set up into place. Even the dealer was impressed with the factory look. I was just glad it was easy because I have a tendancy to mess up projects that only require duct tape to fix /forums/images/graemlins/blush.gif
   / Bucket lights? #17
Don & Bob,
Thank You Both.
You have cut my cost by almost 50%.
   / Bucket lights? #18
TSC sells a sealed toggle switch for about $7.50. Not as nice looking as the rockers though...
   / Bucket lights? #19
willy; My lights are installed for winter/snow removal. Beleive or not, bugs really don't bother me then! /forums/images/graemlins/smirk.gif
As far as glare, I tried them last night, and I do get a little off my glasses, but not enough to bother me much. /forums/images/graemlins/grin.gif
   / Bucket lights? #20
Front facing for snow removal.
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
Mobile toilet with shower (A53424)
Mobile toilet with...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
