bucket issue
   / bucket issue #1
Ford335
Ford 335
Hello, i have a 1975 Ford 335. The Tractor has a ford bucket attachment 19-532. I have gotten a lot of use out of this tractor. Yesterday i was moving a lot of dirt around. When i grab a bucket full the bucket would not hold a load. I backed up,i can raise and lower the bucket but can only curl slightly and then it drops down. Should i start with the cylinders or controls or somewhere else?
   / bucket issue #2
I would start by checking all the hydraulic connections that involve the bucket and its movement. Not just a visual check. Grab the hose - near each connector - give it a good shake. Good possibility that one or more have come loose.
   / bucket issue #3
If your hydraulic lines have quick connect fittings, disconnect, clean and reconnect the lines. With loader issues this is the best place to start.
If you can easily swap the lift/lower hoses with the curl/dump hoses swapping will tell you if the issue is cylinder or valve related.
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
XCMG CV83PD (A53317)
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
