bucket hydraulics Ford 4000
   / bucket hydraulics Ford 4000 #1
RGShields
Calgary Alberta
FOrd 4000
I replaced the direction control valve and all the seals on the cylinders. I have bled the lines to the equivalent of the full volume of the hydraulic system but the bucket raise or tilt up is jerky. Lower or tilt down is smooth but the tilt is very sloppy (moves if I put the weight of the bucket on it) Also, at times I will pull the raise lever and nothing will happen for maybe 10 seconds, then it will jerkily raise.
Any suggestions as to how to troubleshoot or what the problem might be?
   / bucket hydraulics Ford 4000 #2
The symptoms you are describing sounds like air in the system. Check the inlet line to your hydraulic pump. If there is a vacuum leak in this line it could cause this problem. Does the pump sound noisy under load?
   / bucket hydraulics Ford 4000 #3
If you have air or a leak on the suction line you will get foamy oil. Check the reservoir for that. Does it happen at all engine speeds? Sounds like maybe a pump going. If you have internal bypass in the pump it will act slow. Any difference after it warms up?
2025 New/Unused 72in Wolverine Grapple Bucket (A51573)
2025 New/Unused...
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2025 New/Unused...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
