Bucket hits right side first....
/ Bucket hits right side first.... #1
CMV
Platinum Member
NC
Kioti NX4510HST (previous LS XJ2025H, JD 500C)
I noticed that when I let the bucket down, the right side always hits first. Didn't think much of it and assumed uneven ground. But had it on my concrete driveway and noticed there too. Just too make sure, I turned around and faced the other direction and same thing. I also checked and adjusted tire pressure thinking that was #2 suspect. It's not by much, but the right side hits, and then for the bucket to be flat on the ground, it will raise the left of the tractor a bit. Probably about an inch difference right to left. Is that normal? Is it anything to care about?
/ Bucket hits right side first.... #2
No not normal. Check the timing bar if it has it. Should be level
Brett
/ Bucket hits right side first.... #3
Sounds like a tweaked/racked loader frame.
/ Bucket hits right side first.... #4
Mine was the same, and I checked the tires and the frame but they were good. Turned out my bucket had a slight twist which I corrected with some force using the tractor.
/ Bucket hits right side first.... #5
My Massey Ferguson was the same way. I ended up loosening the mount bolt to the frame on level concrete and lowering the bucket. The mount shifted just a bit. I tightened it all back down, and was good to go. Never had a problem again.
/ Bucket hits right side first.... #6
looks like my loader does the same thing, didn't investigate it much but noticed it last night when putting my tractor back in the garage.
/ Bucket hits right side first.... #7
Like others have noted your FEL Frame is probably racked. Perhaps you can try putting a block under far right end of your bucket then slowly try to lift the front of tractor with loader.
Do this several times then back up and lower bucket, to a flat surface, and see if you have improved your situation.
I didn't take off bucket and look that way, but yes, that's pretty much what I experience with bucket on. Like left side is maybe an inch higher and to have bucket flat on ground some weight comes up off left front tire like that.
Here is mine as best as I could get pictures.
UNUSED WOLVERINE PFF3-13-45W UNIVERSAL MAST (A62131)
UNUSED WOLVERINE...
2018 CATERPILLAR 906M WHEEL LOADER (A62129)
2018 CATERPILLAR...
2020 BOBCAT T770 SKID STEER (A62129)
2020 BOBCAT T770...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
UNUSED KIVEL 48" PALLET FORKS (A62130)
UNUSED KIVEL 48"...
(2) 9.5-24 TIRES W/8 LUG RIMS (A62130)
(2) 9.5-24 TIRES...
