Forks Bucket forks from Yankee Warehouse?
   / Bucket forks from Yankee Warehouse? #1
Rusty
Hampton Township, Bay County, Michigan
Kubota B7500HSD-R
Does anyone have chain-on bucket forks (ebay item No. 280024942241) from Yankee Warehouse? Do you like them? Any complaints? Do you recommend them? I am looking at them for a Kubota B7500 HSD with LA 302 FEL. Sorry, I can't seem to set up a direct link to the ebay auction.
   / Bucket forks from Yankee Warehouse? #3
PM Mad Referee and he will send you plans to make some nice clamp on ones. I've just gone through the same thought process. He says his can be made for $50-75 in materials. You will end up paying that in shipping with the ebay ones.
   / Bucket forks from Yankee Warehouse? #4
Roxy, The load binders (2 required) will run almost $50 for decent ones if you don't already have some..... BobG in VA
   / Bucket forks from Yankee Warehouse? #5
PS on the load binders. Of course not matter which kind you ultimately get you will need the binders (usually not included with forks). I would suggest the ratchet type vs the "pull, strain, and lock up" type....Just a thought. BobG in VA
roxynoodle: Thanks! :) I have been following your thread on forks, also. My application is similar to yours: stacking/unstacking of square hay bales and some lifting of light implements. No pallets at this time. The offer from Mad Referee is very generous, however, I have not welded for over 20 years, and then only enough to really appreciate and admire what a good welder can do. My son learned to weld at work, but neither of us has ready access to the required equipment. Besides, I have enough other projects without taking on the fabrication of forks. BTW, shipping for forks and binders from Yankee Warehouse is $28 to my ZIP. I would prefer ratchet binders, and might buy them locally. Still considering. :confused:
   / Bucket forks from Yankee Warehouse? #8
Ok, the other guy who was including the binders with his forks on ebay quoted me over $50 for shipping. Sounds like the ones from Yankee Warehouse are a better buy then. If you also buy binders from him, I wonder if he charges extra shipping. I don't weld either, but my neighbor does it for a living and I sent him the instructions on Mad Referee's clamp on ones and have his interest. He is currently putting back together an Oliver tractor with a FEL and I think he wants some, too, to load his hay. I'm sure the chain and binder ones work fine, just thought I might prefer the clamp on ones.
roxynoodle: The shipping for the lever binders is currently free from Yankee Warehouse, when they are bought with a set of forks.
   / Bucket forks from Yankee Warehouse? #10
Then he has the better deal. If my neighbor doesn't make me the clamp on forks, that is probably what I will buy, too.
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55315)
Case Wheels for...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2016 PETERBILT 579 TANDEM AXLE MID ROOF SLEEPER TRUCK (A54607)
2016 PETERBILT 579...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
1991 Cummins NT-855-G5 250kW 3-Phase Diesel Generator (A55851)
1991 Cummins...
