Bucket Float
/ Bucket Float #1
KubotaMan7
CT
Kubota 7610
Hey guys, on my 7610 I noticed when I push the joystick on the float position in no longer stays, it just clicks and falls back to the middle....does anyone know what the problem could be?? Thanks
/ Bucket Float #2
Mine has always done that. I didn't know that some joysticks were able to stay in the float position.
/ Bucket Float #3
I have a 7610 I have to hold it to stay in float.I release it and it goes out of float.
tony3542
/ Bucket Float #5
It should stay in the float position, My previous B7500 and the L2800 I now have both would hold the float position.
It maybe something as simple as a good cleaning or it could be internal.
/ Bucket Float #6
My B7500 locks in place when I push it into float....but it took me a long time to even find the float. I was not pushing it far enough up.
/ Bucket Float #7
This subject has come up in the past. I just did a search 'float joystick' and found the following:
"A couple of the posts talked about removing the 'cover-nut' on the bottom of the spool (below the lift valve) and finding water there that kept the valve from reaching the detent position. I went out an opened mine up and sure-enough there was water in the cap. I dumped that out and lubed it up with some grease and woohoo now it works like new again."
Hopefully this helps.
/ Bucket Float #8
Kubotaman7,
Wally is right on the money. Take those cast caps off of the underside of the joystick. (Nothing should come out but possibly some condensed water) Spray them down with some WD then coat them with grease. I never had a problem after this application.
There is a thread somewhere in this vast collection of wisdom that will probably explain it better than I just did.
Big Dad
/ Bucket Float
Thanks for all thr help guys, im gonna take it apart and clean it up.
/ Bucket Float #10
Detent position inside valve wears down, allowing control to slip out of float position without normally required light tug. I think the rebuild kit is about 25 bucks from Kubota. I ordered the kit, but my dealer ended up installing it for me for another 25 bucks (50 total) while my tractor was in for 1250 hour service. He showed me how it was done - it seemed simple enough.
Removing condensation from behind cap didn't work for me - she was just plain worn out. Works like new now, just like the rest of the tractor!
Steiner 450 (A64126)
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
