bucket fast dump
   / bucket fast dump #11
Tim I have a 6500 4WD with the same loader. The fast dump on my loader does not make any sound. I have called my dealer on any problems and had them fixed by dealer.Having said this I would not change fluid myself. THIS TRACTOR IS UNDER WARRANTY. I bought a new tractor so problems would NOT be MY problem.
Will
   / bucket fast dump
Mad that explanation helped out a lot. Thanks for reposting that! I'll have to try it out again to see if it is as bad as I am making it sound. It was at idle so maybe it just needed a little more throttle. I will for sure turn in any problem I have. It does work like it should, and the bucket moves much faster. I just wanted to make sure I wasn't overtaxing anything.
   / bucket fast dump #13
since reading this i tried mine and it works fine, no noise. i didnt even know i had it, i kinda had to pop it a little to go to the fast dump.
   / bucket fast dump #14
Tried mine out last nite, works fine, no noise.
I think I read about it in manual but never tried it.
The detent is a little stiff to push in.
   / bucket fast dump #15
I did not know what a fast dump was much less if I even had this feature. Turns out I do and it works quite well. It does not make any unusual noise.
   / bucket fast dump
Finally stopped raining long enough last weekend to get out with the tractor! I think there may have been air in the lines before because now the sound is gone. Fast dump works fine. I probably only have 10 hours on the tractor. /forums/images/graemlins/smile.gif
   / bucket fast dump
used the fast dump a bunch this weekend. I heard the noise again. I think it has to do with if you have something heavy in the bucket and the fluid can't keep up with the drop of the bucket. It is kinda like a sucking sound. I don't think there is anything wrong, still works fine and no leaks. I'll check the resivoir to make sure it's at the right level.
2015 BOBCAT E35 EXCAVATOR (A51242)
2015 BOBCAT E35...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2017 Ford Explorer (A50324)
2017 Ford Explorer...
Tree Boom (A50322)
Tree Boom (A50322)
