Bucket Cutting Edge--Need Advice Regarding Replacement
   / Bucket Cutting Edge--Need Advice Regarding Replacement #21
Sure, I can make you a good deal.
As far as cutting edges wrapped on the ends, many industrial loaders are that way. Also FoMoCo tractor front end loaders were that way.
The cutting edge also cuts on the side, and is why it is wrapped. It is designed to "bit in and cut as well to help prevent wear on the lip and also help the bucket to "penetrate" into a solid bank more. When you've used one like that, you'll see the difference.
   / Bucket Cutting Edge--Need Advice Regarding Replacement #22
Hey Mark,
I've been sending you PMs and trying your phone number for a couple of weeks....
   / Bucket Cutting Edge--Need Advice Regarding Replacement #23
I am sorry about that. I've had a heavier than normal call load due to some internal restructuring of our tech support (which is good and some how my notifications of pms on most of my forums has gotten turned off or blocked or something. I have to physically check them now. Couple that with a new phone that I am still learning after having my old one for 4 years...and I've been goofing up on quite a few calls lately.
Anyway, I'll check and respond some time tomorrow.
   / Bucket Cutting Edge--Need Advice Regarding Replacement #24
Figured something whacky was going on which is why I replied here. It's not an emergency, just a silly/simple question I can't sort out :D
   / Bucket Cutting Edge--Need Advice Regarding Replacement #25
I've read where the welders with plasma and high frequency Tig welders have problems. I don't know anything about Everlast multi-process welders. I have a Lincoln V350-Pro multi-process welder.
Cramming multiple processes & plasma into one box results in compromises. I was looking at a combo unit to get plasma & replace my Miller Maxstar 200. Ended up just getting a dedicated Everlast 60@ plasma (don't remember the model offhand). I still want AC TIG & MIG, but will get a dedicated MIG box at some point. Will probably end up trading the DC only Maxstar 200 in for an AC/DC unit if I ever start doing aluminum. Everlast is high on my list after good results with the plasma cutter.
(1) 12ft Tarter Livestock Panel (A48837)
(1) 12ft Tarter...
UNUSED KJ 20' X 30' METAL GARAGE (A50460)
UNUSED KJ 20' X...
2022 INTERNATIONAL MV607 26FT BOX TRUCK (A50505)
2022 INTERNATIONAL...
UNUSED CFG SKID STEER AUGER SET (A50460)
UNUSED CFG SKID...
2015 John Deere TS Gator 4x4 Utility Cart (A49346)
2015 John Deere TS...
2016 Ford F-550 4x4 Landscape Dump Truck (A48081)
2016 Ford F-550...
