BT750C Boom cylinder seal kit
   / BT750C Boom cylinder seal kit #1
PKSHARP
Hughesville, MD
FORD 4000 IND
Folks. I have a B20 with BT750C backhoe. The boom cylinder is leaking. Messicks and my local Kabota dealer says Kabota does not sell that seal kit anymore?? Anyone know of a replacement part (its 75591-22300 in the Messicks online diagram) ?
Also, when removing the cylinder pins anything special to be aware of? looks like my ford, remove retaining bolt and knock.
thanks for any help and advice
kevin
   / BT750C Boom cylinder seal kit #2
Kubota likely didn't make the seal, nor did they make the ram. The seal should be available from any local bearing or hydraulic shop. If you're uncomfortable performing the repair yourself a local hydraulic shop can probably do the whole job and you'll end up with a like new cylinder.
Thanks dropped off the cylinders at local hydraulic shop. Seams none of the Kabota dealers or online parts houses can cross referance the seals.
R/Kevin
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2005 GENIE Z-45/25 TELESCOPIC MANLIFT (A51246)
2005 GENIE Z-45/25...
CHAMPION 7500 WATT GAS GENERATOR (A51248)
CHAMPION 7500 WATT...
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
