Backhoe BT1100 backhoe leakdown rate?
/ BT1100 backhoe leakdown rate? #1
paulrandal
Snohomish, WA
Kubota L48TLB
Folks,
Does anyone know the spec leakdown rate for the boom cylinder in a BT1100 fitted to an L48? I noticed yesterday as I was driving about (over somewhat bumpy ground) that from having it fully raised, it would have about an inch of piston showing after 10-15 minutes. I'm guessing this is normal, given the weight of the dipper and bucket? I have about 10 hours on the L48.
Thanks
/ BT1100 backhoe leakdown rate? #2
Our BT1000 on our L39 does about the same, as do the stabilizers but they both pretty much stop after that for a considerable amount of time. After 6-7 days they are still at the same place.
/ BT1100 backhoe leakdown rate? #3
That is totally normal. That is why they come with the easy to install pins so the changing pressure of driving around a job site doesn't cause the cylinders and valves to leak down.
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
(INOP) MCCORMICK FARMALL SUPER A TRACTOR (A64277)
(INOP) MCCORMICK...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Hedge Posts (A65640)
2004 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2004 INTERNATIONAL...
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
