Backhoe BT1100 backhoe leakdown rate?
   / BT1100 backhoe leakdown rate? #1
paulrandal
Snohomish, WA
Kubota L48TLB
Folks,
Does anyone know the spec leakdown rate for the boom cylinder in a BT1100 fitted to an L48? I noticed yesterday as I was driving about (over somewhat bumpy ground) that from having it fully raised, it would have about an inch of piston showing after 10-15 minutes. I'm guessing this is normal, given the weight of the dipper and bucket? I have about 10 hours on the L48.
   / BT1100 backhoe leakdown rate? #2
Our BT1000 on our L39 does about the same, as do the stabilizers but they both pretty much stop after that for a considerable amount of time. After 6-7 days they are still at the same place.
   / BT1100 backhoe leakdown rate? #3
That is totally normal. That is why they come with the easy to install pins so the changing pressure of driving around a job site doesn't cause the cylinders and valves to leak down.
2017 FREIGHTLINER CASCADIA TANDEM SLEEPER (A52576)
2017 FREIGHTLINER...
2020 COLOMBO TM LOT NUMBER 217 (A53084)
2020 COLOMBO TM...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2017 Bomag BMP 8500 Walk-Behind Articulated Tandem Compactor (A51691)
2017 Bomag BMP...
2016 Ford Explorer...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 78"...
