Brushmowing Trails. Looking for recommendations.
   / Brushmowing Trails. Looking for recommendations.
That’s a beast! I maintain a couple miles of trails in NW Ontario. Most are inaccessible to a half ton and require an ATV or tractor and the trails are only about 10’ wide, some narrower. Turning around is tight!
I first did it all by hand with a Stihl FS110 but I saw an old Swisher pull behind finish mower by a roadside so stopped to talk, and bought it for I think $225. A new belt & blades and I started using it with my Honda Foreman. It was not made for bush hogging but worked well enough, and sure beat doing it by hand.
A couple years later I started looking for a tractor and one seller had a rough cut Swisher 44” pull behind in his garage. I asked, and he was planning to sell it, and I got the like new machine for $400. I sold my little Swisher for a small profit and began using the new one. It handled saplings better but unfortunately the tongue was so long I could no longer fit it + my Foreman in my landscape trailer to run to my 11 mile distant piece so had to first run the ATV then drive back, drag the 440# Swisher onto the trailer, and repeat. The long tongue also made it impossible to 3-point turn at the end of some trails so I’d unhook it and manually swing it around. That was a problem when I hit a hole with a Swisher wheel.
I finally bought a B2320 with a bush hog and sold the 2nd Swisher, making a little money again. The B2320 gets into spots about as well as the ATV + cutter but my trails aren’t to wet and not “steep”.
I’ll bet that cutter will handle about anything you come across!
Thanks for the info; I have a couple of Kubota tractors - a B3200HSD and a bigger M5040; I brush hog about 10 acres of fields and some of the tamer trails but there are a lot of trails where tractors are a no go - even wheeled ATVs do a lot of a damage to trails and will get stuck pulling a 700+ pound mower. FYI - I have ahydraulic tilt-and-level on my B's 3PT hitch. game changer -- use it mostly with a box blade and sometimes a regular blade.
Awesome. I love my Kunz!!
The guys there are awesome. When I was looking to buy they offered to swing by on their way home from the Louisville equipment show.
Mine is the 57", and she is 6 years old.
nice to hear - I try to minimize the motorized crap I have around here but given my trail profiles I think the Kunz behind a tracked ATV was the "cheapest" option.
9 miles of brush cutting is a lot..however dont buy a bush hog --they are for just cutting grass...buy a brush hog mower,,they are twice the price of a bush hog or more ,but they will do the work,,you probably would tear up 8 bush hogs doing the same thing
Agree.... If money was no object - a tracked brush mower would be awesome - ended up with a workable solution (as long as it doesn't have a lot of mechanical or engine problems) given that I already had tracked machines; wheeled vehicles on my trails towing a 700+ pound mower are not viable.
The other two "critical" or at least incredibly important elements of my setup with the Kunz is the electric lift kit and remote PTO clutch switch; both are mounted on the ATV with easy to disconnect wiring.. For field mowing, maybe not so important but for trail mowing, one has got to be able to lift the deck and cycle the PTO from the vehicle. Again, not a must have but a big part of a workable solution. Also got flat-free tires (not a must have but nice). Kunz also offers anti-scalp and "wet land" options. Anti-scalp not needed for my narrow deck (44") and the wet land option adds more wheels -- might have been nice for stability purposes but not a must have for me (I hope).
Again, thanks to all for the postings. Alway appreciated.
Thank you for posting a follow up to your problem. I am not a fan of pull behind mowers, however I cannot think of a more perfect solution to mowing 9 miles of challenging trails.
me neither - but it seemed like the "cheapest" solution.
   / Brushmowing Trails. Looking for recommendations. #38
It looks like you found a great setup, thanks for the pics of it.
   / Brushmowing Trails. Looking for recommendations. #39
2009 Chevrolet C8500 Dump Truck, VIN # 1GBT8C4B59F409922 (A57453)
2009 Chevrolet...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56435)
2022 Brush Wolf...
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
