Mowing Brushhog blade change??
/ Brushhog blade change?? #1
RxRatedZ71
Edmond, OK
JD 3203
So I was brushhogging this AM and found my way onto a near flush-cut eastern red cedar stump (hard as he$#) and then my BH started making an odd noise. Looked underneath only to see one blade hung up on the pan. Couldnt free it in the field so had to flip it over and remove the pan. Turns out that the dealer/factory put a blade on upside down. Its been cutting with the backside of that blade all the time.Probably explains why the clippings arent cut up that well. Got it righted and back up and running and it cuts alot better. However but it seems to want to wobble. Should I be concerned? Should I try to sharpen the other dulled blade or buy a new set and keep these for spares?
/ Brushhog blade change?? #2
I think I would buy a new set of blades and install them, just to see if there is still some "wobble" going on. That could possibly be a bent pan, or worse, a bent output shaft on the gearbox. I think you need to try and narrow it down and blades would be the easiest starting point. Hopefully that will solve the vibration problem.
/ Brushhog blade change?? #3
If one blade was taking all the abuse on the sharpened side could cause a wobble. My dad and his mechanic experimented one time with a push mower. They taped a quarter on one side of the blade to see what would happen. It took out the engine!
Wow, talk about getting their moneys worth.
I thought about sharpening the dull one but thought might really exagerate the difference and compound the effects.
/ Brushhog blade change?? #5
I'd try a new set of blades, and take the old ones somewhere to get sharpened. I'd ask them to trying making them similar to one another...even if that means taking a little extra off the better blade.
CONVEYOR BELT (A67714)
2018 Manitou MLT634 7,000lb 4x4 Rough Terrain Telehandler (A66734)
2018 Manitou...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2007 TORO 3300-D CART (A66091)
2007 TORO 3300-D...
20' CONNEX BOX (A67714)
20' CONNEX BOX...
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
