Rotary Cutter brushbull 48 crossbar and stumpjumper
   / brushbull 48 crossbar and stumpjumper #1
pgagne
NH
John Deere 790 4x4
goin thru used bb48 I just purchased. Previous owner had wrong blades on crossbar, therefore blades wouldn't rotate on shoulder pins. Put correct blades on after grinding all rust off stumpjumper. Blades still don't rotate on pin shoulders. Looking at parts for sale, found stump jumper and crossbar as two separate items. My existing one is welded to each other. The existing stump jumper is not flat so I believe this is why they won't spin on pins. My neighbor says "run it" and they"ll loosen up. Should the stumpjumper and crossbar be welded as one unit, or is it OK to buy 2 separate items and bolt on? I have already taken stump jumper/crossbar off and reassembled hoping to find cure for non rotating blades.
   / brushbull 48 crossbar and stumpjumper #2
Mine has welds holding the crossbar in place.
My bb48x vibrated when the welds broke.
I replaced with new stump jumper.
Thank for response. I've never seen them not welded. Will call supplier, I may have misinterpreted schematic. If not, will look for stump jumper and crossbar as one unit as they do take a beating.
2022 Adams CLC-1013 Conveyor - New (A53472)
2022 Adams...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A53472)
2015 RAM 5500...
