Rotary Cutter brushbull 48 crossbar and stumpjumper
   / brushbull 48 crossbar and stumpjumper #1
pgagne
NH
John Deere 790 4x4
goin thru used bb48 I just purchased. Previous owner had wrong blades on crossbar, therefore blades wouldn't rotate on shoulder pins. Put correct blades on after grinding all rust off stumpjumper. Blades still don't rotate on pin shoulders. Looking at parts for sale, found stump jumper and crossbar as two separate items. My existing one is welded to each other. The existing stump jumper is not flat so I believe this is why they won't spin on pins. My neighbor says "run it" and they"ll loosen up. Should the stumpjumper and crossbar be welded as one unit, or is it OK to buy 2 separate items and bolt on? I have already taken stump jumper/crossbar off and reassembled hoping to find cure for non rotating blades.
   / brushbull 48 crossbar and stumpjumper #2
Mine has welds holding the crossbar in place.
My bb48x vibrated when the welds broke.
I replaced with new stump jumper.
Thank for response. I've never seen them not welded. Will call supplier, I may have misinterpreted schematic. If not, will look for stump jumper and crossbar as one unit as they do take a beating.
2000 FORD F650 SINGLE AXLE DUMP TRUCK (A52472)
2000 FORD F650...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2025 JOHN DEERE Z325E LOT NUMBER 87 (A53084)
2025 JOHN DEERE...
2022 NORSTAR (A52472)
