Brush mowers
   / Brush mowers #1
Tractorman13
Nevada
4 Kubotas
Can anyone out there that has had both three point brush mowers and pull type tell me the advantages of both. I have two threepoint brush mowers and wanted to puchase another but thought I woul find out if there are any advantages to pull type. Thanks
   / Brush mowers #2
First let me say that I don't have a pull type. But I will give my opinion anyway. /forums/images/graemlins/grin.gif There are 2 pull type configurations. One has wheels mounted at the rear of the deck. The other has the wheels mounted mid deck. Both pull like a trailer.
The main advantage is that it will follow the contour of the ground instead of rising and falling as the tractor goes over bumps and dips. That should give a more even cut over uneven ground. The mid wheel mount should be the least likely to scalp.
The main disadvantage would be that backing up would be like backing a trailer, much more time consuming than a 3 pt.
   / Brush mowers #3
The other thing I found about pull behind type is the angle of the pto drive shaft can get quite tight and put quite a strain in things . Actually bent a pto shaft in the tractor once. Kind of a project splitting the tractor and opening up the trans to replace the shaft. I use a 3 point now . I man learns a lot about his tractor when you have to "open it up"
   / Brush mowers
Sounds like the three point mowers are better,I was just asking because if pull behind mowers had some advantages I was going to try one. Thanks
   / Brush mowers #5
U can use a larger and more HD mower than u can lift w/ 3 pt.
I used to pull a HD 7' Bushhog w/ a Super H.
But in soft ground if the mower goes down u r STUCK.
Like others said sharp turns break PTOs.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2019 RAM CUTAWAY SERVICE BODY TRUCK (A52577)
2019 RAM CUTAWAY...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
19101 (A51694)
19101 (A51694)
R&G Trailblazer 1000Gal 28% Applicator (A52349)
R&G Trailblazer...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
