Brush Hog Width for TC35
   / Brush Hog Width for TC35 #1
mbtracy
I'm looking to purchase my first Brush Hog for my newly purchased TC35 which is 6' wide. I need to cut a 1 1/2 acre field, maybe only twice a year and I would like to cleanup about 2 acres of woods.
My question is, what width unit should I buy? Does it need to be the same width as the tractor? Since I don't think I'll be using it all that often, I want to spend as little as possible. I'm looking at the RZ60 for $725.
   / Brush Hog Width for TC35 #2
I think a 60" bush hog would be fine. I know a lot of people run a 72" on a tractor your size, but I think that is too wide i fyou get into heavy stuff. I run a 60" on my Ford 2120 which is larger than yours by several sizes.
Andy
   / Brush Hog Width for TC35 #3
the TC35 is the class III isnt it...
I run a 5' behind my TC33...worked great this weekend, brush and thick tall grass seemed to be no problem.
   / Brush Hog Width for TC35 #4
I have a Case DX35 (same size tractor in Red from CNH) and I run a 60" bush hog. You don't need anything bigger for what you are going to do and a 72" bush hog will be a lot more expensive. Plus, if you are using it in the woods, the wider bush hog may get hung up on a tree if it extends past your tires. I think you are making the right choice with the RZ60.
2004 DYNAPAC CA152PD PADFOOT ROLLER (A51242)
2004 DYNAPAC...
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
UNUSED FUTURE MINI EXCAVATOR GRAPPLE (A51244)
UNUSED FUTURE MINI...
2002 International 9200i Truck (A52128)
2002 International...
UNUSED FUTURE MINI EXCAVATOR HYD BREAKER (A51244)
2019 BOBCAT S770 SKID STEER (A51242)
2019 BOBCAT S770...
