Brush Hog - Tractor Supply
   / Brush Hog - Tractor Supply #1
Scrambler82
Veteran Member
SoCal
Mahindra Max 28XL, HST, TLB
Hello,
It has been a while, the SoCal remodel on the house is completed and the yard work is more of a big job than thought, not just Landscaping but the maintaining of the Fields as a Fire Protection. (A problem in a Flash Fire Area - Fire Department Mandated).
I purchased a Brush Hog from Tractor Supply, over a year ago, and just got it on about a month or so back.
I am using the 60" model of the Country Line Implement and so far it is an amazing tool.
My wife and I have been dreading cutting the side field after a wet winter and I didn't know which way to turn so I broke down and set myself to attaching the Brush Hog and making the necessary adjustments.
Well folks, all I can say is it turned out to be a easier than I thought to cut the driveshaft to fit my tractor, and top link threw me for a while but I'm getting the idea of the adjustment. I still have a slight problem with the Tool digging-in in the front more often than I like but I lift it a little and it seems to help me but I need to add some larger skids to the front and do a little more adjusting.
But the Brush Hog itself, not the heaviest duty tool in my tool box, but it is strong enough to handle my work load and then some... it definitely made my life easier. Cutting the 4 to 5 foot weeds in the side yard alone, was a breeze, this things ate through the weeds like they weren't even there and after the second pass the next day the field actually looks a little like a lawn... not my intent, but from a distance it looks good.
Once I got started I had cut for over 5 hours, the side field, alone my 1/4 mile driveway, and along the main road, which should be covered by the HOA but for some reason my end of the HOA appears not to be on the list. (At least I get the mani road graded), and the upper five acres, had a few rocks but this Hog was easily maneuvered through the rock field and cut the weeds easily with a better look than expected.
So if anyone was thinking about "CountryLine" from Tractor Supply, it does what is needed in a medium duty package, and for the average land owner it should work.
Thanks for reading, I do get carried away... once in a while.
Ltr
p.s. I hope to update this thread as soon as I get some more time on the tool, but I am thinking it should be a good tool for a long time. Biggest thing... GREASE IT REGULARLY, before each use is not a bad thing.
   / Brush Hog - Tractor Supply #2
Can it actually cut brush up upto 3" thick?
Not likely.
I have cut into some small bushes, approximately 1 to 1.5", I really didn't look but some were very dry. Does that make cutting easier... not sure. Usually backing over them with the tool raised, then I lower it and move forward, so far it has worked out ok.
I have not attempted anything larger but it seems like it didn't have any problem with the 1.5" stock BUT... cutting heavy stock may decrease the life of the tool.
I don't like to use things to their max specifications, I buy heavier duty than needed and don't usually use it to the max spec., that way they live longer.
   / Brush Hog - Tractor Supply #5
Mowing tends to put a lot of stuff in the air and clog the tractor's radiator screen. Clean it more often.
If your mower has a slip clutch it needs to be slipped and adjusted once per season.
I also mow for fire clearance and don't mow once the grass is dry. It's too likely to generate sparks.
   / Brush Hog - Tractor Supply #6
Another very important aspect is to check the oil level regularly in the gear box on the brush hog.
Since I am new to using the Brush Hog, I didn't even think about the Fire Hazard, thank you for the suggestion; I WILL follow the suggestion !
Yes Checking the Oil in the Gear Box is as important as the grease in the Universals.
Thank for filling in the missing Lubrication !
Thanks for the replies !
   / Brush Hog - Tractor Supply #8
Where did you come up with 3" ? Or are you needing that capacity? Bush Hog has cutters rated for 3", as do other makers.
   / Brush Hog - Tractor Supply #9
At 3" i want the stump out....
   / Brush Hog - Tractor Supply #10
Don’t forget to carry a large fire extinguisher while hogging.
SORKO MC19-10 LOT NUMBER 149 (A53084)
SORKO MC19-10 LOT...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
2024 JOHN DEERE 3039R LOT NUMBER 58 (A53084)
2024 JOHN DEERE...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
