Brush hog slip clutch
   / Brush hog slip clutch #11
Another thread, somebody mentioned using spray penetrating fluid for annual maintenance on slip clutches.
Has anyone else successfully used this method to keep them reliable?
I don't think any kind of oil/petroleum product would be good for the "clutches". I think they're some sort of fiber material?
   / Brush hog slip clutch #12
be sure they slip like they should or the
results will be damage to the clutch.
I thought that if the slip clutch didn't slip like it was supposed to, the damage would be to the drive gears in the rear of the tractor!
David from jax
   / Brush hog slip clutch #13
My "light duty" rotary (also a RCR1260) doesn't have a slip clutch, just an oft-breaking (because of me) shear bolt. Am I bad that I removed the shroud that was always in the way of replacing the shear bolt? Seems to me a superfluous bit of safety kit given that you shouldn't be anywhere near the gearbox when that thing is running!
I have a slip clutch on my heavy tiller and it obviously works because a, I catch a lot of hefty rocks when tilling new ground and b, my tractor isn't broken (yet). Definitely do the loosen the clutch and make sure it spins thing on that, though I haven't torqued it before - great idea!
1302 (A58374)
1302 (A58374)
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
526 (A52708)
526 (A52708)
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
Skid Steer Concrete Mixing Bucket (New/Unused) (A59225)
Skid Steer...
