Brush Hog Question
/ Brush Hog Question #22
Wow, I've never heard of that!!!! Sounds very dangerous.
I read about it here on TBN. I had a top link pin on the shredder side of the top link that was too long. It limited the travel. I was thinking about a chain in place of the top link, and I read about the possibility of a flip up.
Maybe a year later I was mowing with a different tractor which has ROPS. I went between two trees I know I had mowed between before. The shredder caught both trees, flipped up, lifted up, and got past the trees. I got off to have a look. I had badly bent a cat 2 pin on the left side, bent the top link to the point it was not useable anymore, and bent a skid shoe into the shape of a donut, shearing off 1 of the 2 mounting bolts.
/ Brush Hog Question #23
Top link chain does sound very risky. I have had them kick up before but never had a problem because it was newer equipment that had the proper top links with a little bit of play. I would also worry about a chain top link getting wrapped up in the pto shaft.
/ Brush Hog Question #24
My 20-year-old Bush Hog brand cutter has an A-frame that connects to a solid top link and to the two lower arms. There is a chain from the A-frame down to the rear of the mower. Works great, and allows plenty of slack for backing up banks and to go over swales.
100 Gal Oil Container (A64127)
100 Gal Oil...
John Deere 6110M (A64126)
John Deere 6110M...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
John Deere 995 (A64126)
John Deere 995...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A65583)
New/Unused...
