Brush Hog Blade Sharpening
   / Brush Hog Blade Sharpening #41
IF YOU WANT IT TO CUT AS GOOD AS NEW YOU MUST ALWAYS BE SURE THE EDGE STAYS STRAIGHT ACROSS AND GET IT RAZOR SHARP THEN DULL THE EDGE A LITTLE WITH GRINDER TO KEEP IT FROM NICKING OR KNOCKING OUT CHUNKS OF THE EDGE- 90% OF THE CUTTING TAKES PLACE AT ABOUT 1" FROM END OF BLADE
   / Brush Hog Blade Sharpening #42
Welcome to TBN, And as a reminder all caps is hard to read and considered 'yelling'.:confused3:
   / Brush Hog Blade Sharpening #43
I still don't understand why people insist on sharpening them razor sharp AND THEN proceeding to dull them with a grinder.
You can either quit before you are razor sharp and save material, or leave them razor sharp. They aren't going to deform or chunk or dull any different.
   / Brush Hog Blade Sharpening #44
'Cause people just don't get it?!:confused3: They're not cutting steaks!:confused2:
   / Brush Hog Blade Sharpening #45
A number of years ago I only sharpened the blades to somewhere around the first picture above because it took too long to sharpen them further. My brother would give me a hard time, but our cuts looked the same. Years later he came over saying he read that you don't want a sharp blade. I just looked at him and said "told ya". Every now and then cutting corners pays off.
So many on here talk about brush hogging like they do it every year. What kind of brush are you having to mow that keeps coming back like that? Or are you hiring out to cut other people's brush? Most of my hogging is just clipping the weeds and tall grass stalks the cows don't eat. Any brush trying to grow is young and not hard on the mower. The hogging is mostly clean up duty.
   / Brush Hog Blade Sharpening #46
Bush hogging is usually a twice a year job in different areas. Not always at the same time, so I use it about 5-6 times a year at least.
The pasture does just get once a year.
   / Brush Hog Blade Sharpening #47
I cut about 250-300 acres a year commercially. Many repeat or 3 and 4 times a year contracts. Many new jobs that who knows what I will get into.
I have a set of high lift blades that are kept sharp for those that I know is gonna be just light weeds and grass. Those repeat pasture clippings or commercial jobs that get done 3+ times a year.
My other set of blades is for the new or on-off cuttings where I may be into rose bushes 10' high, or lots of saplings and trees. Those blades stay blunt and only every once in awhile will I smooth out some of the damage from hitting rocks or whatever
   / Brush Hog Blade Sharpening #48
I typically sharpen my blades once a year in the winter when I try to get all my maintenance done...
Never used a flapper wheel before but will use one now...
Thanks for the info guys...
I appreciate it...
   / Brush Hog Blade Sharpening #49
I place mine under a pyramid for about a week. Gets them RAZOR SHARP!
Ever wish you never would have asked a question? This is one of those times.
23105 (A56859)
23105 (A56859)
2008 FORD F-650 SUPER DUTY (A58214)
2008 FORD F-650...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
EquipmentDealz (Shipping Terms and Instructions) (A59213)
EquipmentDealz...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2021 Ford F-150 (A55973)
2021 Ford F-150...
