Brush Hog blade replacement
/ Brush Hog blade replacement #1
ericm979
Super Member
Southern Oregon
Branson 3725H Deere 5105
The Brush Hog SQ172 I got with a piece of property has extremely worn blades. I ordered some blades and bolts. Does anyone know the wrench size of the nut (part number 252BH)?
/ Brush Hog blade replacement #2
No idea of the nut size. However - you best be prepared with a LONG handle breaker bar or impact wrench to get that nut off.
Two years ago. I changed the three blades on my JD 570 riding mower. They had been on the mower five years. I almost herniated myself trying to get the blade bolts loose. That's why I now own an impact wrench. AND a good supply of WD40.
I have a 1200ft lb air impact wrench on order because the three I have are for automotive use and are not heavy duty enough. I need to get some Kroil penetrating oil too.
/ Brush Hog blade replacement #4
have a Sq600 which is an older version of the current Sq160 Bushhog which is a 5 ft cutter vs your 6 ft. My nut size is 1 11/16. Not sure if both models take the keyed bolts but I would think they are same blade bolts just different blades
/ Brush Hog blade replacement #5
3 years ago I changed out the blades for the first time on my General SE-6 mower (a Rhino clone) after having used the mower for 23 years. So I was surprised when the nuts came off the bolts readily (using my half-inch drive IR impact). 32mm was the size of the socket that fit those nuts.
/ Brush Hog blade replacement #6
I have a circa 1989 Bush Hog SQ72 and the nuts for the blades are also 1 11/16".
/ Brush Hog blade replacement #7
ATF + acetone works well to loosen up stuck bolts for me. Or you can heat the bolts with a torch and let candle wax soak into the threads. But you'll want to clean this stuff off before you reassemble.
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
1999 GROVE MZ66DXT TELESCOPIC BOOM LIFT (A65053)
1999 GROVE MZ66DXT...
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
County Line 3Pt Chisel (A66408)
County Line 3Pt...
4 Bottom Plow (A65640)
SWINGTEC D-88307 COLD FOGGING APPLICATOR (A64276)
SWINGTEC D-88307...
