Brush Cutter RPM
   / Brush Cutter RPM #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
Does anyone know the max RPM of the Brush Cutter?
   / Brush Cutter RPM #2
JJ
Pt specs say PTO flow is 8 gpm, and with a 3.0 cubic inch per rev hydraulic motor, this equates to 618 rpm.
Hope this helps
Duane
   / Brush Cutter RPM
Thanks.
If I am right, that means that you are using 11.7 hp to turn the Brush Cutter on the smaller machines.
   / Brush Cutter RPM #4
That sounds about right, but you only use the amount of power you draw from the load of cutting and turning the mower. Just to turn the cutter would be alot less.
2023 BOBCAT T770 SKID STEER (A51246)
2023 BOBCAT T770...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2018 Kia Soul Crossover SUV (A51694)
2018 Kia Soul...
2017 FORD F150 REG CAB LONG BED 4X4 (A52577)
2017 FORD F150 REG...
2019 CATERPILLAR 330GC LONG REACH EXCAVATOR (A51246)
2019 CATERPILLAR...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A53472)
2015 Ford F550...
