Brush cutter gear oil leak
   / Brush cutter gear oil leak #1
TVZ
Bronze Member
MF 1726E
My King Kutter brush hog is losing gear oil from the gear box. It's not coming out around the gear box on top of the deck. Any idea where it would be coming out?
   / Brush cutter gear oil leak #2
I'm confused. Leaking oil should be pretty easy to trace. Bottom/output seal, input seal, cover gasket or fill/drain plug. ?
   / Brush cutter gear oil leak #3
Pump the gearbox full of grease and don't worry about it.
Well, you see, I don't know the first thing about the seals, where they are, how to check them, etc.. I'll watch some YouTubes about them. Thanks.
Really? You mean grease like goes into the grease fittings? Just shoot it in the gear oil fill-hole? I like this idea!
Any further advice on doing this? Fill it all the way up?
   / Brush cutter gear oil leak #6
Some will say use corn head grease, personally I have pumped 2 gearboxes full of regular off the shelf grease and have never had another problem, pump a cartridge full in the fill hole of your gearbox and about once a year whenever you do maintenance on your mower pump a little in the gearbox, you will be fine.
   / Brush cutter gear oil leak #7
If grease filled brush hog gearbox was trouble free & the way to go, I wonder how come they are not designed that way to start with?
To me it sounds like a bit of a band-aid fix...
   / Brush cutter gear oil leak #8
Feel the top of the stump jumper...is it oily up there? The bottom seal is an easy job once you get the stump jumper off.
  • Good Post
Reactions: TVZ
   / Brush cutter gear oil leak #9
Yep a band aid fix that will last as long as he owns the cutter.
TOFT 06ER Excavator Ripper (A49251)
TOFT 06ER...
2007 John Deere 320 (A47164)
2007 John Deere...
XZ20K-C Diesel Excavator (A49251)
XZ20K-C Diesel...
MadVac 101-D Sweeper 2WD (A49251)
MadVac 101-D...
3ft Cultipacker (A49251)
3ft Cultipacker...
TYM Tractor (for PARTS) (A49251)
TYM Tractor (for...
