Brush cutter blade bolt
   / Brush cutter blade bolt #1
STx
Bandera, Tx
New Holland TC40 DA, Deere 17D, Hyster SX50 forklift, Case D450, Kubota ZD1011-54, International Dump Truck, Kubota SVL-952S, Volovo EC250DL
Is this a fairly standard blade bolt? It came off a skid steer brush cutter, I've seen some round shoulder bolts online that look like they might work. Does TSC or a dealer typically stock a part like this?
   / Brush cutter blade bolt #2
I doubt it.. what brand cutter ?
Nice cutter...I would call them and get a few..
Thanks, it's a beast.
I sent them an email, can't find a phone number on their site.IMG_20200325_134738.jpg
I still haven't heard back from JCT so I country noted a fix with some top link bushings and a grade 8 bolt. It works for about 45m and then sheers off. I took the broken bolt to the machine shop to have them.make me a couple of 1 piece bushings that I can drop a bolt through in the hopes that will hold up better. If it doesn't, then I'll pull the stump jumper off and enlarge the hole in it so that I can use a regular rotary cutter blade bolt that I can pick up at TSC.
I think the original bolts sheered because I was running too much hydraulic flow and turning everything too quickly. I've cut that down now and hope that the bushings I'm having made will be a permanent fix. I definitely can't be having to replace a bolt every 45 minutes of cutting.IMG_20200326_164812.jpg
   / Brush cutter blade bolt #7
I would change them to the TSC ones and grind a flat on the head then weld a piece of square stock on the disc to keep the bolt from turning.....:2cents:
You're probably right, it's wallowed out the hole in the stump jumper some already so that hole needs to be enlarged regardless. I think I'll drop the blades and the stump jumper off at the machine shop Monday with a couple of blade bolts. I don't have the tools to drill hardened steel without frustration, especially not 5/8 and 7/8 thick hardened steel.IMG_20200328_143254.jpg
   / Brush cutter blade bolt #9
I would get 4 at least , You don't want the bolt turning it the hole.... you only need about 1'' of square stock welded on one side and the ends....
I decided to have the blades and stump jumper modified to accept a common brush cutter bolt I could get at TSC. I had the machine shop enlarge both holes and cut a key slot into the stump jumper and use a bolt that had a key in it. I picked it up yesterday and ran it a little, it’s much better this way. The blade swings freely but the bolt is locked into the stump jumper by the key and being torqued down to 300 ft/lbs or so with a lock washer. I think I’ll probably break something else before the bolt fails again.
I never did get any response from the manufacturer (JCT) and I’m seeing a whole lot of their brand new equipment at the Ritchie Bros auctions lately so I’m wondering if they’ve gone out of business. I guess I’m on my own for any repair parts so I’m glad I made the change, even though it was a bit more expensive than I’d have liked.
2013 FREIGHTLINER CASCADIA DUMP TRUCK (A54313)
2013 FREIGHTLINER...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
1995 Generac 94A05603S Diesel Generator (A51691)
1995 Generac...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
12 in Small Excavator Bucket (A52377)
12 in Small...
