Brush Cutter Backstops
/ Brush Cutter Backstops #1
Well, I snapped my first bolt on my brush cutter! It's a rite of passage I'm glad to have passed. It stayed under the mower deck, no flying, no impaling, no bleeding. Snapped a backstop bolt off simultaneously (I think/assume)
I dug through the old posts on brush mower attachments here and Bobrip posted about putting some rubber bumpers made of horse matting on his backstop bolts. I just wanted to see if Bob (or anyone else who has done a simliar mod) had any comments/long term report on that improvement.
I will say, the 425 was amazing at clearing large mutiflora and other brush. I was making clearings/paths to/around downed trees that I want to cut up as fire wood and it really did the trick. I now know why y'all say it's the only tractor that will go where a atv will go.
Thanks,
Chris
/ Brush Cutter Backstops #2
I have gone through huge rounds with my mower... I did horse mat, tried to do tire, did hockey pucks (moderate success).
Currently I am at hardened grade 8 bolts with a stack of washers attached. The washers are bent up a bit, but the Grade 8s seem to be holding. Not looking forward to me being wrong on this one.
One thing, I have 3 rotors under my deck. The one that is powered directly by the hydraulic motor and two that are belt driven. The belt driven have the stoppers on them, but on the main drive I have no stoppers at all. Just put in hex caps in the holes. I found that the direct drive rotor was unlikely to have the blade sticking to the stump jumper like the other two.
I have some pix, somewhere...
/ Brush Cutter Backstops #3
Get longer stop bolts and put a nut on them before threading them in. That will take care of a lot of the problems. The blades will no longer pass over the bolts and jam.
Starting the cutter with the throttle at idle helps a lot, if you aren't already doing that.
/ Brush Cutter Backstops #4
Thanks,
Chris
The rubber horse mat did not last long. I think the grade 8 bolts with a stack of cheap washers is the best that I have tried so far. They get bent after awhile and break, but hold up for quite a while.
There must be something that would crush and recover, maybe a spring would work. Just thought of that. Weld the middle of two springs to the bolt head, forming an X with the bolt head at the cross of the X , so that the end of at least one spring ( or maybe two) would be hit by the blade. This would give a longer deceleration distance and time and soak up the energy with less damage to the blade and the spring assembly. Sounds real good. Somebody try that and let us know. What was I doing tomorrow, maybe this.
I was hoping the rubber solution would mean less blade bending. I noticed that my blades have a bit of curve to them and was thinking that at least part of that is probably the slamming against the stops when bouncing off a stump/rock.
I have been incorporating start at idle into my habits, but I'm not 100% yet, especially when stomping brush down and restarting the blades repeatedly when clearing, though there seems to be little slam then as the brush is taking the starting force.
/ Brush Cutter Backstops #7
For those of you who aren't familiar with them, the 3PH cutters that are used with CUTs don't have these problems because they don't have stops. Their blades are mounted on a wide pan called a stump jumper and are height staggered so that they can pass over each others bolt ends. They don't need stops.
Hundreds of manufacturers large and small use this tried, true, and reliable system, but not Power Trac, who has to mount the blades on a cheesy brake drum in order to save a couple of dollars. :mad:
Edit: By height staggered, I mean they are mildly Z shaped. See the pic, which happens to be a high lift blade, too.
/ Brush Cutter Backstops #8
I also made my own new blades. Not sure I did the right thing in my design, but basically went to 1/2" hardened stock, had the edge cut up, and then bent the trailing edge up a bit to get lift. My originals were heavily bowed and the front edges looked like the back edges, they were so easily dented.
I will say mowing late summer things are a LOT dustier than they used to be. Not sure if my cuts are any better (once I get the brush cut down and sprayed, I put in orchard grass) so now I am cutting a lot of grass...
/ Brush Cutter Backstops #9
Snow, could we modify the drum to match the standard brush cutter?
/ Brush Cutter Backstops #10
I think it would have to be replaced. It would be a lot of work with some engineering required.
If there is someone out there with access to a 48" 3PH cutter, could you measure the width of the stump jumper and post the results?
/ Brush Cutter Backstops #11
I am pretty sure the blades take on that curve because they tend to hang somewhat from the mounting bolts and the first time you ground the the blades, the tips hit first and want to bend up. I have gone through several sets of blades and every one has taken on that curve within 1 hour of mowing. it does not affect performance at all. I find the PT brush mower kind of amazing in that, the blades can be about as sharp as two by fours and will still cut your lawn. Don't even want to think what kind of blade tip speed is going on under there.
/ Brush Cutter Backstops #12
My six foot 3PH cutter is the same way. The blades look like they started WWIII and lost. They still cut perfectly well.
(I started to write perfectly fine, but no rotary cutter cuts fine in the grass sense of the word, even when new.)
/ Brush Cutter Backstops #13
Some years ago, or i should say many years ago, being very "smart" young man, i went ahead and sharpened up the blades on the brush hog. Not a disaster but the ranch supervisor took some time to explain to me it was a waste of time and that those "dull" blades would shatter the woody stems on brush and small trees. The shattered trunks were not sharp so little chance of injury to stock and they broke down faster without sending new shoots.
He did appreciate the initiative how ever. :eek:
/ Brush Cutter Backstops #14
I've sharpened my brushhog blades a few times, both on and off the mower. I never saw a noticible difference in cutting results. Thanks, cqaigy2, for helping me understand "why".
Phil
I found a set of energy suspension polyurethane suspension bushings Welcome to Energy Suspension! from an old truck in my shop. I think if I can find a metal bushing to span the size difference between the bolt and the hole in the hard red puck things I'll give them a whirl.
/ Brush Cutter Backstops #16
Thats a good idea. I just sold my friggin charger and I had a bucket of bushings from Energy that I was going to put in the car but never did....
I wonder if they would survive (The energy bushings). The hockeypucks were OK, soft enough to bounce, hard enough not to cut... There is a lot of force under that deck.
John Deere 6120M (A57148)
John Deere 6120M...
2008 HINO 26FT NON CDL BOX TRUCK (A59905)
2008 HINO 26FT NON...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2015 VOLVO VNL SLEEPER (A59905)
2015 VOLVO VNL...
(28) 2"X3"X33" TUBING (A60430)
(28) 2"X3"X33"...
UNUSED FUTURE P45-56" HYD MINI BREAKER HAMMER (A60432)
UNUSED FUTURE...
