Rotary Cutter Brush Bull Rotary Cutter
   / Brush Bull Rotary Cutter #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
I contacted one of my local implement suppliers and asked him for a recommendation on a rotary cutter (did not specify size or use) and a post hole digger with a 9" auger. He asked me (1) Horsepower of my tractor and (2) Lawn or field. He recommended;
5' Woods BrushBull - $860.
Leinbach with a 9" auger - $425.
I had also called my friendly TSC. They recommended;
5' KK - $1,000 (they don't stock the 4' model)
Post Hole Digger with 9" auger - $470
I'm kind of surprised that TSC came out more 14% more expensive, or are the Woods mower and Leinbach unit of lesser quality?
   / Brush Bull Rotary Cutter #2
That's a good price on the Woods Brush Bull. I had two different dealers quote me $960-980 for the 5' standard duty, and that was as part of the package deal at the time of buying the tractor.
--Brad
   / Brush Bull Rotary Cutter #3
I'm looking into a 5' rotary cutter purchase this Spring. I've already been convinced (from here) not to buy a used one. I've been quoted $1,195 for a Woods Brush Bull, with shear pin protection from my local dealer. I was quoted $899 for the same machine from a dealer in VT where I saved $300 on my Meteor blower this past Fall. Upgrade to a slip clutch is $993. I'm thinking that would be $94 well spent???
Brad - The dealer mentioned that the regular price was $1,075. Plue he agreed to deliver the mower, post hole digger and a rotary spreader 15 miles to me for another $45.
P.C. - Hopefully others can chime in about the slip clutch. $94 seems like a good price although I think I recall threads on TBN that indicate some maintenance is needed on slip clutches? So, if the area you're cutting is likely to consume vast quantities of shear bolts/pins, a slip clutch is desirable. If not, it might be cheaper and less work to buy a few shear bolts/pins.
   / Brush Bull Rotary Cutter #5
Leinbach is definitely not lesser quality. I have a number of leinbach equipment items (check my profile for pics) including the post hole digger. They are just affordable. I paid $395 with a 9inch auger. As for slip clutch/shear pin my opinion is this. I have a slip clutch on my rhino. If you are going to be cutting saplings or hitting stumps and rocks a lot then the slip clutch will work out a lot better and pay for itself. If you will just be mowing fields and rarely do any ruff stuff then save the money and use shear pins.
2013 Chevrolet Cruze Sedan (A50324)
2013 Chevrolet...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2014 Caterpillar 257D Compact Track Loader Skid Steer (A50322)
2014 Caterpillar...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
