Browser Speed Tests
/ Browser Speed Tests #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
This morning I thought I'd test the claim that Opera (V6) is the world's fastest browser by testing at DSL Reports
My DSL connection is, theoretically, 640/160.
Browser - dl/ul
Netscape 4.7 - 513/134
IE 5 - 513/132
Opera V6 - 435/2
Now, while the download speed of 2 is an anomaly, the 435 (15% slower) probably is not. What speeds do you all see?
/ Browser Speed Tests #2
Uhhh, Mike?
That's a line speed test, which has little if anything to do with your browser. /w3tcompact/icons/crazy.gif (Somebody feel free to correct me if I'm wrong.)
If you want to test browser speed, pick a long, complicated web page somewhere and see which browser can read and render it the fastest. Right off the bat I know that Netscape has a brain-damaged way of opening and closing a separate connection for almost every component of the page, and is also real slow at rendering (figuring out how to draw) the html.
Don't know if there's a standard browser-tester page out there, but there might be. /w3tcompact/icons/wink.gif
You're right. That was a line test. Doh! /w3tcompact/icons/crazy.gif
I found a better Browser Test Site
/ Browser Speed Tests #4
Mike,
Here's the results with IE 5.5 at work.
The throughput timing test using Server 1 showed
your actual throughput was then averaging about 800Kbps.
The second (Server 2) throughput timing test showed your
actual throughput was then averaging about 4667Kbps.
The final (Server 3) throughput timing test showed your
actual throughput was then averaging about 875Kbps.
The overall average of these tests was 2114Kbps.
Terry
<pre> Server 1 Server 2 Server 3 Overall
Opera 5 2154 Kbps 2153 Kbps 1547 Kbps 1951 Kbps
IE 5.5 1212 Kbps 1647 Kbps 1327 Kbps 1395 Kbps </pre>
Interesting. Opera is about 40% faster
UNUSED KJ 42'X30' METAL STORAGE SHED (A62131)
UNUSED KJ 42'X30'...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
John Deere 6300 (A60462)
John Deere 6300...
JOB BOX (A62130)
JOB BOX (A62130)
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
CASE 105C (A62177)
CASE 105C (A62177)
Here are some similar links:
