Brown Snot in diesel fuel?
   / Brown Snot in diesel fuel? #11
That happened years ago when I had an oil furnace. I couldn't believe anything living could live in fuel oil or diesel!
   / Brown Snot in diesel fuel? #13
I just went through the same thing on a friend’s tractor I was working on. I attempted to remove the tank to do a proper cleaning but I came to the conclusion it was impossible without dissembling the dash and that was too much work. A fuel filter was only $6.50 so I just put it back together. Hopefully it doesn’t prove to much aggravation with stopping up filters.
   / Brown Snot in diesel fuel? #14
OP, if you put an 'inspection camera' down into your tank the biological growth will be at the bottom and will look like fairy-floss (cotton-candy) mixed with phlegm.
Yeah Mate, you'll need to drain the diesel tank (and dispose of that fuel), then pour in at least 5liters (or a US Gallon) of diesel biological treatment (ship chandler can get it for you) and let that sit for at least 24hrs. Change the fuel filter.
Then drain the tank and, using a long 'grabber' and CHUX (J-Cloth) wipe the inside of the tank until there's no more crud coming out.
You can then re-fill with fresh diesel WITH a regular sized biological treatment. Add this treatment every time you fuel your tractor.
Depending on the treatment you purchase, you may need to change the fuel filter a few times in the future to ensure that the dead biological residue, that's present in the lines, doesn't clog it up.
Good luck.
   / Brown Snot in diesel fuel? #15
Plugs up an oil burner nozzle fast too.:oops:
I was always cleaning and replacing burner nozzles, usually at 2 a.m. in January. I checked for transformer spark with a screwdriver once...Once. It backfired and wife said I looked like Al Jolson. It took a long time for my eyebrows and beard to grow back...my hair never did.
   / Brown Snot in diesel fuel? #16
Go buy some Biocide and a couple of fuel filters..
Once the biocide does it’s thing, the “husks” will clog ur filter.. easily noted by a drop in rpm..
   / Brown Snot in diesel fuel? #17
When you add the new fuel and your afraid that some water
just might still be some in your tank toss in a can of HEAT it
will take care of the water. Truckers use is a lot!
willy
This is my plan. Thanks.
   / Brown Snot in diesel fuel? #19
I would drain the tank and wash it out then start with fresh fuel and biocide...been there done that....if you have a surplus tank it needs to be treated as well..
The last thing you want is for any to make it past a filter into a injection pump or injectors..
   / Brown Snot in diesel fuel? #20
I just discovered a crop of bug goo in my rearmost filter, I found I actually deleted the photo because it made me sick to look at it…lol
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
FAE 150/540 LOT NUMBER 137 (A53084)
FAE 150/540 LOT...
2025 New/Unused LandHero 1 in Air Impact Wrench (A51573)
2025 New/Unused...
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
