BROKEN WIRE INSIDE WELDER
   / BROKEN WIRE INSIDE WELDER
Your grandfather was right - its the pragmatic approach to repair work that counts. As a bush mechanic, I work on the same principle - it only needs to outlast me, then it is someone else's problem
   / BROKEN WIRE INSIDE WELDER #12
LOL... I frequently work on 90+ year old cars. Asked why I put so much effort into a restoration, my reply is always; "So it'll last another 90+ years".
Today is my 66th birthday. I hope all my restorations out-live me.
   / BROKEN WIRE INSIDE WELDER #13
Good idea Redneck. I do have an 8 ton hand operated hydraulic crimper with multiple dies that use for boat rigging. If the repair already made fails, I'll use that to crimp a new wire to the aluminium one
   / BROKEN WIRE INSIDE WELDER #15
Aluminum and copper don't play nice when in contact with each other. (google aluminum wire house fires - caused by aluminum to copper joints in wire splices and terminations on circuit breakers with copper lugs). The aluminum corrodes and makes a high impedance joint that can overheat and cause fires, or if you're lucky it just "rots off" like yours did.
There is special split nuts that keep the conductors from contacting each other, also solder and flux for joining aluminum to copper, but it's finicky - Tinning the aluminum can be challenging. There are also end-to-end screw-compression splices (think butt splice, but with setscrews) that are made specifically for joining aluminum to copper while not allowing them to contact each other like they do in a regular split nut. I think they're made out of tinned aluminum, commonly used for electrical service drops to a house. The tin doesn't react with the copper or the aluminum. You can get them at electrical supply stores.
A bit of good info here: Need to Connect 240 volt Alum to Copper Wiring - DoItYourself.com Community Forums
If you stick with the split nut splice in the picture, at least goober the wires with no-ox or similar oxide inhibiting compound.
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A58214)
2012 TROXELL...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
NEW Landhero Mini Skid Steer Loader 23HP (A59000)
NEW Landhero Mini...
2013 FORD F-350 XL SUPER DUTY- FLAT BED (A58214)
2013 FORD F-350 XL...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56435)
2008 Ford F-250...
2019 BOBCAT T590 SKID STEER (A52709)
2019 BOBCAT T590...
