Tires Broken valve stem
/ Broken valve stem #1
freewookie
Guthrie, OK
JD GT235, DK40SE HST
Broke a valve stem on the front tire of my DK40. It looks like it has a nut at the base of the stem but not sure if it screws apart or you cut it from the back side of the rim. I tried a standard racket but it spins on the inside. Didn't want to drag a compressor and impact wrench out to where I left it if it doesn't really screw off.
Thanks
/ Broken valve stem
Never mind. I put a pair of vice grips on the backside and got it out. Not to find a replacement on a Labor Day...ugh.
/ Broken valve stem #3
A regular valve stem will work if you just need the tractor. Walmart or tractor supply should have these. Otherwise you will probably need to visit a tire shop for a bolt in. The bolt in ones are a little tougher and should be all brass with the rubber sealing washer.
/ Broken valve stem
I have Kubota, New Holland and JD all within 10 minutes so I'm hoping one of them might have some.
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
Landhonor ATS-ME18 Mini Excavator (A66285)
Landhonor ATS-ME18...
7ft Metal Texaco Pump (A65583)
7ft Metal Texaco...
Hedge Posts (A65640)
New/Unused Wolverine 48in Mini Combination Bucket (A65583)
New/Unused...
Troy-Bilt Pony Riding Mower (A65579)
Troy-Bilt Pony...
