Tires Broken valve stem
   / Broken valve stem #1
freewookie
Guthrie, OK
JD GT235, DK40SE HST
Broke a valve stem on the front tire of my DK40. It looks like it has a nut at the base of the stem but not sure if it screws apart or you cut it from the back side of the rim. I tried a standard racket but it spins on the inside. Didn't want to drag a compressor and impact wrench out to where I left it if it doesn't really screw off.
   / Broken valve stem
Never mind. I put a pair of vice grips on the backside and got it out. Not to find a replacement on a Labor Day...ugh.
   / Broken valve stem #3
A regular valve stem will work if you just need the tractor. Walmart or tractor supply should have these. Otherwise you will probably need to visit a tire shop for a bolt in. The bolt in ones are a little tougher and should be all brass with the rubber sealing washer.
   / Broken valve stem
I have Kubota, New Holland and JD all within 10 minutes so I'm hoping one of them might have some.
Blue Diamond Quick Attach Brush Mower (A50514)
Blue Diamond Quick...
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52128)
2020 Massey...
John Deere 8430 Track Tractor (A50514)
John Deere 8430...
SET OF (2) TITAN HI-TRACTION TRACTOR TIRES/WHEELS (A51244)
SET OF (2) TITAN...
