Broken tire valve stem
   / Broken tire valve stem #11
boomer613 said:
How is it putting the loaded tire back on? I'm thinking I will have a chore putting my "unloaded" tire on by myself.
It is, just like I said previously though. Main thing is don't lay it down and don't let it lay down on you. Roll it to tracktor, wiggle back and forth to get it close to lined up and adjust height of tractor accordingly. Same way you would do it if you never lay the tire down or lift it. Of course my tractor is a ford 640 and doesn't use combine tires :D
   / Broken tire valve stem #12
The 3.5 ton floor jack will work fine to lift the back of your tractor. I use a 2.5 ton with mine.
You didn't say what tire you have (AG, Industrial, or lawn tires) but if they are lawn tires you can probably break the bead and replace the stem yourself. Ag and Industrial tires take a little more work to break the bead. In the past I've laid the tire down and put a 2 x 10 on the tire close to the rim then drove my truck up the 2x10 to break the bead and replace a stem. Now I have a tire machine that does that for me. Or you can get it off and take it to the shop on a trailer. 200 lbs isn't too bad to lift with a helper.
I was able to bring my tire to the tire shop. They charge me only $10 - this included the brass stem. It took them only 10 minutes to replace the tire stem. They broke the bead (industrial tire) with an axe. It seemed much easier then using a pry bar. Putting on the tire back on the tractor was a piece of cake. Didn't even have to physically lift it. Adjusting the right height on the floor jack did the trick. All I had to do was line it up with the first bolt and then I manipulated the jack until the second bolt lined up. It took me 5 minutest with no effort. I could see it being done almost as easy with loaded tires. Thanks again everyone!
   / Broken tire valve stem #15
I found this thread while searching for valve stem sizes for the rear of my DK50.
Second weekend in a row that I have lost a valve stem.
Last Saturday I lost a front and the tire bead got cut. I had to replace a brand new tire and lost a week.
Today I lost a rear valve stem. I had to carry a jack, cribbing, tools and a chainsaw(to get more cribbing from a tree trunk) back in the woods(only a couple hundred yards). It was a chore getting the wheel and tire off in the mud.
As luck would have it, by the time I got the wheel and tire back to my truck and got it loaded(that sucker is heavy for 1 man), all the tire shops were closed.
I have about 13 hours on this tractor. Monday I'm taking the tires to get them foam filled.
   / Broken tire valve stem #17
foam filled ? are you running on nails ? if things happen in the wood, maybe you are just running too much pressure in the tires ?
New Holland TS6.120 Power Shuttle 4WD 120HP Agricultural Tractor (A56857)
New Holland...
48'' ALUMINUM MAN BASKET (A56857)
48'' ALUMINUM MAN...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
2 Warehouse Forks (A55787)
2 Warehouse Forks...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
