Broken tie-rod
   / Broken tie-rod #1
scappoose
Scappoose, Oregon
mahindra 2816/FEL
Yesterday as I was driving my Mahindra 2816 in my driveway a peice of 1/2" plywood stood up on edge and broke my tie-rod in half. I have discovered that the tie rod its self is only a rather thin metal sleeve with nuts on either end. I suspect that the sleeve could be threaded (like a turnbuckle). Does anyone know if it would be possible to repair and strengthen this tie-rod turnbuckle?
The tie-rod its self appears to totaly straight. does anyone know how long this tie-bar/turnbuckle should be?
My thought is to cut off the broken parts of the sleeve and weld a piece of steel rod inside and then reinforce the whole tie bar with angle iron.
What do you folks think of this solution?
Even if I buy a new tie-bar,I would still like to strengthen it in some way. does anyone have any suggestions
   / Broken tie-rod #2
i routinely make draglinks for my fords. just metal tube / pipe ) with some sort of coupler ont he end, depending on the style and type of tie rod end.
I'd go pipe befroe i scabbed angle iron on.. if only for cosmetic savings.. :)
   / Broken tie-rod #3
Better to break the tie rod than what its connected to. You may want to keep that in mind before you build the worlds strongest tie rod. Good luck.
   / Broken tie-rod #4
Hey, Ken, thats experience speaking isn;'t it? A very good point, sometimes it's engineering, not just saving weight or being cheaper? But I tend to Gorilla weld it back??
Bobcat Skidloader PHD (A50774)
Bobcat Skidloader...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A52748)
2023 NEW HOLLAND...
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
NEW Woods 6ft Finish Mower (A52748)
NEW Woods 6ft...
