Broken tie rod mount
   / Broken tie rod mount #1
jwcinpk
Veteran Member
Welfare Capital of the World...KY
2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
Well I finally did get 50 hours on the 7010. Went to my dealer and he made me a hose up to replace the one that burst. Thought I was back in business for a while. I had about 20 or so acres that I needed to get grass growing on so I hooked up the disc and started to work. Made about 5 passes around the field and bam as I made a left turn the left front wheel never came back straight. On further inspection I found that the tie rod mount had broken. This is going to be a definate trip to the dealer.
I'll try to get a pic up and provide a link to it.
   / Broken tie rod mount #3
Not good!:(
How did you get it out of the field?
Raised the front end off the ground with the loader and pallet forks and drove backwards steering with the brakes. Not exactly easy! Aleast now it is where it can be loaded.
   / Broken tie rod mount #5
jwcinpk said:
I would hope Mahindra would cover that even if its out of warranty (assuming they can't prove you did this as a result of abuse) under the "latent defects" laws that many states have. Such defects can be detected many years after any warranty is up if it can be proved that it was a bad casting from the start....BobG in VA
Never had any trouble with a Mahindra warranty claim and I've made a few, but you never know. I could see nothing wrong with the casting. I can't explain how it broke. I've put the 6000 through some pretty tough stuff and never had any problem with it. Actually what I was discing with it was a lot rougher. We were pulling a light disc across a bulldozed feild with the 7010. The field wasn't rough, but it did have a root rake used on it so it wasn't pancake smooth either. It was a bit steep and turning to come up the hill to the left. Either way it's got to be fixed and with such low hours and only having it since January it's still got lots of warranty left.
Just wondering how long it's going to be before they release that 8560 cab 4x4. Now would be a convenient time to trade!
   / Broken tie rod mount #7
The last time I asked my sales rep when it would be available I was told mid January. Seems to me that was a couple of months ago. Funny isn't it!
I can't pin anyone at Mahindra down on a date. That's the biggest reason I went with the 7010. I needed another tractor and wanted a cab to get through this winter. I was told it would be at the Farm Show in Louisville and then found out shortly before that it would not be. I'm told it's something to do with customs. Something about they would not let it out of port. That was last month. This is purely me repeating what I was told. I don't know if it has an ounce of truth.
As I said this would be a convenient time to trade. If there was one sitting on the lot I might not be able to resist!
   / Broken tie rod mount #9
Joel,
So sorry to hear (and see) your third problem with your 7010. I do wish Mahindra would do something concrete with 8560.
hugs, Brandi
bindian said:
Joel,
hugs, Brandi
I geuss there are bugs to work out on any new tractor. Actually I've had 4 problems with the 7010. 1-The injection timing was not correct 2-leaking loader valve o ring 3-FEL hose burst 4-Broken tie rod mount. The only thing that was really a Mahindra problem is the injection timing. The others are TYM and KMW problems. Nothing to get excited about until the tie rod mount. I'm just confused as to how it broke. I know it wasn't abused and the casting looks fine. If this pattern continues I'll certainly be ready to trade by the time the 8560 gets here. At the rate it's going I may have the 7010 paid for by then.
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Bale Ring (A50515)
Bale Ring (A50515)
Kubota RTV500 (A47384)
2018 FREIGHTLINER COLUMBIA GLIDER TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
Wolverine Quick Attach Post Driver (A50515)
Wolverine Quick...
