Broken tie rod mount II
   / Broken tie rod mount II #1
jwcinpk
Welfare Capital of the World...KY
2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
Well the new tie rod mount is significantly different from the old. I was going to get a pic up this morning, but it slipped my mind. I'll get one this evening. Obviously this has been a problem as the dealer has broken one on his tractor and the improved replacement is on mine. This worries me for the future. Anyone with any information on this?
   / Broken tie rod mount II #2
Joel, I have never seen this issue on the 7010.......I have however seen some electrical problems.
   / Broken tie rod mount II #3
I hate to say this, but that 8560 is looking better everyday.:rolleyes:
   / Broken tie rod mount II #5
Joel
Glad to see you are back in business with the 7010. Interesting problem. Let us know why the redesign.
Michelle
   / Broken tie rod mount II #6
Joel, I think that I would ask why weren't both sides changed. Maybe mention to your dealer that it would be a bad deal to be driving along and have the tie rod end fall off from a previous unseen crack. I'm assuming that they fixed the steering so that it can no longer try to travel to far? Best of luck and I hope that you are the first owner of an 8560.:cool:
   / Broken tie rod mount II #7
I too think they should replace both arms . The problem is that on a tractor fitted with a loader or one that has the wheels mounted for narrow track , the steering stops are adjusted to stop fouling . The weak tierod and drag link castings fail as the stops are contacted and the steering is held on full lock or the front tyres hit a rut . The arms are obviously under specked and really to help things a pair of adjustable stops should have been installed on the Pitman arm to stop the over extension at the other end of the steering system as well as the ones at the wheels .
   / Broken tie rod mount II #8
Is that a whole new piece ?
It looks like your old one that has been just repaired.
No, I think it's a new piece. I thought the same thing when I first saw it, but it seems to be a new piece.
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A50323)
2015 Ram 5500...
1999 Case 90XT Skidloader (RUNS) (A50774)
1999 Case 90XT...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
New Edco Hand 12" Post Hole Digger (A50774)
New Edco Hand 12"...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
