broken throttle control on B2150
   / broken throttle control on B2150 #1
LDD
How big of a job is this? Anyone ever replace one? It looks like it broke right in the middle of the lever before it connects to the more internal throttle control. I need to know if there are multiple pieces to the throttle lever (it looks like there are??) Thanks in advance.
   / broken throttle control on B2150 #2
I have a kubota 2150 the throttle handle broke does anyone know how to remove the rest of the handle
   / broken throttle control on B2150 #3
There’s a pin holding the handle to the stem shaft. You’ll need a small punch to push it out. Careful when doing this, as it will impact placing it back in.
   / broken throttle control on B2150 #4
How in the hell did you get a punch down in there to pop that pin out?? You'd have to remove the gauge panel and side panels and dash panel and first the hood. grrrr.
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
UNUSED SDLANCH SDLC2030FT20'X30' ALL STEEL CARPORT (A57193)
UNUSED SDLANCH...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A53422)
2007 Ford F-150...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
