Broken seat mount
/ Broken seat mount #1
clarky711
Upstate, NY
Kubota L3540
I was helping a neighbor move some large chunks of a tree that he felled yesterday, when I noticed the seat mount broke on one side of my L3540. I’ll call my dealer on Monday, but does anyone know if I can get a new mounting tab or do I need to replace the whole seat? Ugh
/ Broken seat mount #2
That's not going to be a 5 minute repair, if even possible. That kind of brake just shouldn't have happened. I'm guessing that you'll be stuck with a whole new seat.
/ Broken seat mount #3
Perhaps you can fab up a bracket and a way to mount the tab to the seat. I might be a bit difficult to weld the tab to the seat without having a thermal event with the foam.
/ Broken seat mount #4
OMG rust should never happen? To tractors left outside?
Id start by trying to disassemble that metal pan under the seat and weld a new tang onto the seat base before buying a whole new seat. Clean all the rusty bits with a wire brush. Put on a nice coat of paint to protect the bare metal before re-assembling.
/ Broken seat mount #5
The seat pan should unfasten from the base giving you access to the hinge. BTW that looks like corrosion wear not only just 'rust'. Either weld with a patch or new bracket. If patched, you might have to carve out a wider slot, but I wouldn't call that a 'major'. The other side is probably ready to fail, too.
/ Broken seat mount #6
Looks like mine would be a easier fix.
/ Broken seat mount #8
Take it apart and see. Might be an easy fix with a piece of steel and a couple holes, or might not be... Won't know until you get eyes on it.
/ Broken seat mount #9
These tabs are likely available from Kubota. This is pic is from Messicks online catalogue for L3540HST (2007 - 2009)
/ Broken seat mount
Thanks very much, that made it easy. A quick online order with a few other filters and the new brackets were here in a day. I got both sides and I am glad I did as the other one was right behind it. They were both rusted and stressed. Even though she lives indoor now, her first 8 years were outside.
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
GUIGONG CLG9035E EXCAVATOR (A62129)
GUIGONG CLG9035E...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
429858 (A61165)
429858 (A61165)
