Broken Pinion in 955 rear transmission
   / Broken Pinion in 955 rear transmission #1
kimodc
Bronze Member
Hello,
I have started to repair my 955 which has a broken pinion shaft in the rear transaxle. Has anyone had any luck welding (tig?) these or should I just look for a new one? From Deere, the pinion and ring gear come as a set for a pretty penny. I was hoping for a cheaper alternative but also want a fix that will work.
   / Broken Pinion in 955 rear transmission #2
Bummer. Might try to find a used combo from a parted out tractor.
Any idea how it happened, or what caused it to happen?
   / Broken Pinion in 955 rear transmission #3
If you can find a good used set I would use them. If you can't then buy new. I don't think this can be welded in away that will be a good fix.
I was thinking I would probably have to find another one, but just wanted to see if anyone had any success with welding one up first.
As far as how it got broken, I don't know because that is how I purchased it. Because it is broken just behind the gear that turns the MFWD, I would assume someone slammed it in to 4wd when the rear wheels were spinning, or maybe too much traction/strain on the driveline on the front wheels while engaged in 4wd?
Thanks for your suggestions.
   / Broken Pinion in 955 rear transmission #5
The part number is AM877016 and unfortunately it's only used on a 955. I googled the part number and came up with new $1200-1300. Pricy part. There were two used ones but no price given.
Thanks pmsmechanic, I ordered up one of the used ones, about half the price of new which seems to be the case with used tractor parts. I should have it here in a couple of days and hopefully up and running within a week of two. Unfortunately it is not the only thing wrong with the tractor, but definitely the biggest problem (I HOPE!)
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
72In FEL HD Round Back Bucket (A51039)
72In FEL HD Round...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
2020 FABRIQUE H9618TRTV-100 18FT ENCLOSED TRAILER (A51222)
2020 FABRIQUE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
