Loader Broken Grease Fittings on FEL
   / Broken Grease Fittings on FEL #1
dirtrustler
Huntsville,Tx
Kubota M7040 4WD
I have two with the head snapped off on my FEL M7040 and I have bought an "Easy-Out" type gadget at my local Orange hardware store - believe it's called a Grab-It or something but am having no luck extracting the buggers.
I need advice and thank you in advance.
Dirtrustler
   / Broken Grease Fittings on FEL #2
I am surprised the easy out did not work. Here is a set that TSC sells. The trick is to match up the screw extractor/easy out with the hole you drilled and to turn the easy out counter-clockwise to remove the screw or in your case the grease fixing.
Great tool as you unscrewing the easy out, the other end is screwing itself in the broken off screw.
Mibro 5 Piece Screw Extractor Set - 3902594 | Tractor Supply Company
   / Broken Grease Fittings on FEL #3
I've used the Easy-out style stud removers and unless they are well and truly seated, they can tend to come loose eat away at the broken stud/zerk etc.
Couple of options. Reverse fluted drill bits are made that will drill when the electric drill is turning in reverse. If you have to drill out a stud to make way for an Easy-out anyway, they are the way to go. In some cases, the drill will even bind to the point where it actually unscrews the broken stud, thus no Easy-Out is required. However, they are special drills and can be hard to find. They also won't work well with a zerk that already has a hole drilled through it.
Second option (which I prefer)
Drill a hole in the offending stud/broken bolt.
Take a 8-12" long drill rod or other high carbon steel rod sized to an appropriate diameter for the stud/zerk that needs to be removed.
Using a bench grinder, grind the drill rod down so you have four flukes with very sharp edges tapering down to perhaps 50% of the original diameter. At the other end of the rod grind two flats for your adjustable wrench. Harden the drill rod with a torch and a container of oil. Once the rod is hardened, drive the tapered end into the broken stud using a ball peen hammer. Keeping hand pressure on the end of the rod use your wrench to unscrew the sud. Sometimes simply hammering in the rod into the stud will loosen it up.
In all cases, use a penetrating fluid first and, if the part can be safely heated without damaging the metal, heating the part can also loosen up broken studs. I've also used insect repellent (bug juice) as a penetrating fluid and it seems to work too, and it also keep the bugs away ;-)
Safety glasses are a must too!
   / Broken Grease Fittings on FEL #4
Buy some good replacement zerts..There is some garbage copys out there that are soft...Might save some future heartache.
   / Broken Grease Fittings on FEL #5
Some of the newer style zerks are not threaded, they are ribbed. They pound in with a hammer, and won't turn out propperly. Just a thought?
--->Paul
   / Broken Grease Fittings on FEL #6
If it were me, I would pull a zerk next the broken one and see what I was dealing with.
E/S
   / Broken Grease Fittings on FEL #7
Get the set of screw extractor from tractor supply it should pull the grease zerk fitting right out. the grabit is more for removing broken bolts or badly damaged screw heads.
The screw extractor slide inside the zero fitting and grab the inner wall and turn the fitting out. While your at tractor supply, get some good quality zero fitting
Brian
   / Broken Grease Fittings on FEL #8
BTTT.....................
Thanks to all who posted. On my way to Tractor Supply and getting a refund from the Big Orange Barn.
Dirtrustler
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A55973)
2012 Chevrolet...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
2013 Nissan Rouge SUV (A56859)
2013 Nissan Rouge...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
